Re: Need help in compiling simple C program [message #209853] |
Fri, 15 February 2008 14:53  |
You are going to have much better luck getting an answer within the CDT
newsgroup...which I have CCd
HTH
Darins
http://runnerwhocodes.blogspot.com
"lee" <huajie.lee@gmail.com> wrote in message
news:52333391d4bf8297106a200257cc71ca$1@www.eclipse.org...
> I have just installed C/C++ eclipse for my Windows Vista.
> I created a folder and add a source file (.C) under the C project. When I
> try to perform Build All, there is error of
> **** Build of configuration Default for project test ****
> (Exec error:Launching failed)
> I do not have idea what actually went wrong.I could not even Run as a
> result of Build error as above. Please let me know what actually went
> wrong.
> My Eclipse version installed is:-3.3.1.1
> Please advise. Thanks.
> -l
Re: Need help in compiling simple C program [message #209899 is a reply to message #209884] |
Sat, 16 February 2008 14:05  |
Originally posted by: eclipsenews.richardmiskin.plus.com
A simple way to get Eclipse+CDT+MingGW all working together is to install
Wascana Desktop Developer. .
http://wascana.sourceforge.net/
Richard
"Jim Marshall" <jim.marshall@wbemsolutions.com> wrote in message
news:fp77qj$vgb$1@build.eclipse.org...
> lee wrote:
>> Nope. I have Windows Vista Business edition and I assume no gcc is
>> preinstalled unless i have to install Cygwin.
>> Please advise.
>> -l
> You would need to install GCC, you have two options. Cygwin or MinGW. The
> short story is that MinGW will produce Native Windows programs, whereas
> Cygwin will produce programs that run on Cygwin*.
> Download and install one or the other:
> 1 MinGW: http://www.mingw.org/
> 2 Cygwin: http://www.cygwin.com/
> The third option, which I don't know how people will respond to on this
> list, is to down load and install the Microsoft compiler and IDE. They
> have a free version (VC++ Express edition -
> http://www.microsoft.com/express/download/default.aspx). I do not think
> you can use the MS compilers from within CDT (unless there is a plugin I
> do not know about)
> * There are ways around that, but lets not complicate the discussion yet.
FUDForum. Page generated in 0.04700 seconds
