Home » Modeling » GMF (Graphical Modeling Framework) » Mapping in XML Schema.
Mapping in XML Schema. [message #209676] Tue, 28 October 2008 04:23 Go to next message
Hello everybody,
I am new with GMF, and I want to program a modeller (a little as UML class
diagramm).
After the modeling I want to make a mapping in XML Schema (XSD).
How can I do? I thought of programming a XSLT file or to use JET.
What advise me you? Have you other propositions?
Thank you for your help.
Pierre
Re: Mapping in XML Schema. [message #209707 is a reply to message #209676] Tue, 28 October 2008 07:24 Go to previous messageGo to next message
Hello pierre,
In EMF you can use XSD document for initializing domain model. As a result
domain model will be stored in XML document according to the passed schema.
I think you can use this feature + GMF to create diagram editor savign domain
model into a file with custom XML schema - AFAIU this way will save you some
time on writing domain model -> xml document tansformation.
Alex Shatalin
Re: Mapping in XML Schema. [message #209898 is a reply to message #209707] Wed, 29 October 2008 10:45 Go to previous messageGo to next message
Hello Alex,
Thank you for your answer !
I think that I don't completely understand your answer. If I have good
understand, I can save a domain model with a custom XML Schema. But in
Mindmap example the .mindmap file is already a XML Schema file? With this
way I obtain a XML Schema file (XXXX.xsd). But I have forgotten to say in
the last message that my diagram models Business Objects (with class...)
and I want a XSD file for each Business Object. What advise me you? I must
a XSLT file too to seperate the XSD file into several XSD files.
I maybe badly expressed myself in my last message. I want to program a XML
Schema (XSD) generator from a diagram. This diagram models Business
Objects and I want to generate a XSD file for each Business Object.
Thank you for your help !
Pierre
Re: Mapping in XML Schema. [message #209908 is a reply to message #209898] Wed, 29 October 2008 11:32 Go to previous message
Pierre,
Comments below.
Pierre wrote:
> Hello Alex,
No, it's a .xml file that conforms to a schema.
> With this way I obtain a XML Schema file (XXXX.xsd).
There's a MindMap.xsd, but the *.mindmap is an instance...
> But I have forgotten to say in the last message that my diagram models
> Business Objects (with class...) and I want a XSD file for each
> Business Object.
So you have some other model, like XSD, Ecore, or UML, that you want to
map to XSD. Perhaps that's similar to
org.eclipse.xsd.ecore.EcoreSchemaBuilder which converts and Ecore
instance to a corresponding XSD instance.
> What advise me you? I must a XSLT file too to seperate the XSD file
Not sure I understand how the separate files issue comes up.
> XML Schema (XSD) generator from a diagram.
That sounds a lot like EcoreSchemaBuilder, so maybe that's where you
want to look.
> This diagram models Business Objects and I want to generate a XSD file
> Pierre
Previous Topic:RootEditPart 'eats' DragnDrop-Operation
Next Topic:how to use java( or ocl if is possible) for a link constraint in gmfmap
Current Time: Wed Sep 10 18:28:28 EDT 2025
Powered by FUDForum. Page generated in 0.04269 seconds
