Home » Archived » Visual Editor (VE) » JInternalFrame visibility
JInternalFrame visibility [message #20243] Sun, 22 February 2004 03:11 Go to next message
Originally posted by: appel__.hotmail.com
I'm using Eclipse M7 with VE-runtime-I20040219.
When adding an JInternalFrame to a JDesktopPane the propertypane for the
internal frame says its visible property is set to true. But it's not.
I think it says in the javadoc for JInternalFrame that one must explicitly
setVisible(true) and that code isn't generated automatically. I had to
first set visible to false, and then true for the correct code to be
generated.
Is this a bug or am I doing something wrong?
/Johan Appelgren
Re: JInternalFrame visibility [message #20247 is a reply to message #20243] Mon, 23 February 2004 09:21 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
For a JInternalFrame, we hide the visible property. For a JInternalFrame
you are supposed to use the show/hide methods, not the visible property.
(I think you may be thinking of the old AWT Frame, you used to use set
visible, but show()/hide() are the expected methods to do this now even
for frame).
I think you may have the contentpane of the internal frame selected
instead of the internal frame itself. The content pane has the visible
property, and it is defaulted to true for it.
Thanks, Rich Kulp
Re: JInternalFrame visibility [message #20639 is a reply to message #20247] Mon, 23 February 2004 16:07 Go to previous message
> for frame).
Yes, you are right.
Thanks.
Re: JInternalFrame visibility [message #582250 is a reply to message #20243] Mon, 23 February 2004 09:21 Go to previous message
for frame).
Thanks, Rich Kulp
Re: JInternalFrame visibility [message #582274 is a reply to message #20247] Mon, 23 February 2004 16:07 Go to previous message
> for frame).
Yes, you are right.
Thanks.
Previous Topic:JInternalFrame visibility
Next Topic:VE1.0.0 compatibility
Current Time: Fri Nov 14 07:13:34 EST 2025
Powered by FUDForum. Page generated in 0.28791 seconds
