| UI Problems [message #20231] |
Sat, 07 June 2008 11:44  |
Almost every subversive dialog has some form of corruption. I'm using
Vista 64 with Eclipse 3.3.2 and the latest Subversive plugin and
connectors.
Check and radio boxes work, but text input fields are usually not shown.
When I want to create a new repository location, for example, under the
"Advanced" tab I'm able to edit all the fields, but under the "SSH" tab I
cannot see the text field for entering the password or the passphrase
(although I'm able to edit the "Port" field).
This problem also happens on the Preferences->SVN page. I can see the
tabs, but no input field (though the frame labels are shown). If I resize
the window, the tabs dissapear. But then, if I resize the splitter, the
tabs come back and this time I can see and am able to edit everything
(even the connector selection box was not available).
I tried uninstalling and reinstalling Subversive and connectors, and also
downloaded the "Eclipse Distro + Subversive Team Provider" from
http://www.polarion.com/products/eclipse, but nothing different happened.
I can get some screenshots if needed.
Thanks for any help,
Fabio
FUDForum. Page generated in 0.03973 seconds
