Home » Language IDEs » C / C++ IDE (CDT) » Problems with ANSI C Refactoring
Problems with ANSI C Refactoring [message #209228] Wed, 06 February 2008 05:52
Originally posted by: ronzon.w3logistics.de
when I try a function out of the C/C++ Refactoring Plugin I get allways
the follwing error message:
An unexpected exception occurred during condition checking. See the error
log for more details.
org.eclipse.cdt.internal.core.dom.parser.c.CASTTranslationUn it
The error log shows:
!ENTRY org.eclipse.ltk.ui.refactoring 4 10000 2008-02-06 11:28:35.509
!MESSAGE Internal Error
!STACK 0
java.lang.reflect.InvocationTargetException
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:350)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:495)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:268)
org.eclipse.ui.internal.progress.ProgressManager$3.run(Progr essManager.java:909)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:944)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:919)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n.checkInitialConditions(RefactoringWizardOpenOperation.java :166)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n.access$0(RefactoringWizardOpenOperation.java:162)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n$1.run(RefactoringWizardOpenOperation.java:125)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n.run(RefactoringWizardOpenOperation.java:154)
org.eclipse.cdt.hsrrefactoring.extractconstant.ExtractConsta ntRefactoringRunner.run(ExtractConstantRefactoringRunner.jav a:42)
org.eclipse.cdt.hsrrefactoring.RefactoringEditorAction.run(R efactoringEditorAction.java:45)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by: java.lang.ClassCastException:
org.eclipse.cdt.hsrrefactoring.commentHandler.CommentedTrans lationUnitFactory.getCommentedTranslationUnit(CommentedTrans lationUnitFactory.java:41)
org.eclipse.cdt.hsrrefactoring.HSRRefactoring.loadTranslatio nUnit(HSRRefactoring.java:280)
org.eclipse.cdt.hsrrefactoring.HSRRefactoring.checkInitialCo nditions(HSRRefactoring.java:228)
org.eclipse.cdt.hsrrefactoring.extractconstant.ExtractConsta ntRefactoring.checkInitialConditions(ExtractConstantRefactor ing.java:93)
org.eclipse.ltk.core.refactoring.CheckConditionsOperation.ru n(CheckConditionsOperation.java:81)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAda pter.run(WorkbenchRunnableAdapter.java:87)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
I Use the C/C++ Plugin version 4.0.1.20070924 with Eclipse Version 3.1.1
Can you help me?
Thomas
Previous Topic:Build stopped working
Next Topic:Enablements in own Plugin
Current Time: Tue Jul 22 00:01:03 EDT 2025
Powered by FUDForum. Page generated in 0.06121 seconds
