Home » Modeling » GMF (Graphical Modeling Framework) » .gmfgraph error
.gmfgraph error [message #209167] Wed, 22 October 2008 08:20 Go to next message
When I try to open .gmfgraph,there is a problem encountered.the details
are as follows:
java.lang.IllegalArgumentException: Figure reference to
org.eclipse.gmf.gmfgraph.impl.DiagramLabelImpl@1b443d5 (name:
DataEntryLabel) (resizeConstraint: NSEW, affixedParentSide: NONE)
(elementIcon: true) could not be resolved for
(elementIcon: true)
org.eclipse.gmf.internal.graphdef.util.MigrationDelegate.set FigureDescriptorForDiagramElement(MigrationDelegate.java:372 )
org.eclipse.gmf.internal.graphdef.util.MigrationDelegate.pos tLoad(MigrationDelegate.java:307)
org.eclipse.gmf.internal.common.migrate.MigrationHelper.post Load(MigrationHelper.java:89)
org.eclipse.gmf.internal.common.migrate.MigrationResource.ha ndlePostLoadException(MigrationResource.java:60)
org.eclipse.gmf.internal.common.migrate.MigrationResource.do Load(MigrationResource.java:40)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
org.eclipse.gmf.gmfgraph.presentation.GMFGraphEditor.createM odelGen(GMFGraphEditor.java:903)
org.eclipse.gmf.gmfgraph.presentation.GMFGraphEditor.createM odel(GMFGraphEditor.java:861)
org.eclipse.gmf.gmfgraph.presentation.GMFGraphEditor.createP ages(GMFGraphEditor.java:960)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2739)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2565)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:286)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:139)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 5)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:316)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:613)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
____________________________________________________________ _____
Does anyone know how to solve this? thanks a lot!
YE
Re: .gmfgraph error [message #209313 is a reply to message #209167] Thu, 23 October 2008 05:39 Go to previous message
Hello yeliu,
This code was modified in last release of GMF, so can you try it with the
latest GMF version?
Alex Shatalin
Previous Topic:start & end point of edge
Next Topic:[Announce] GMF 2.2.0 I200810221928 is available
Current Time: Sun Aug 31 18:38:56 EDT 2025
Powered by FUDForum. Page generated in 0.04080 seconds
