Home » Eclipse Projects » Eclipse Platform » Plugin to open java files into eclipse
Plugin to open java files into eclipse [message #209126] Wed, 10 March 2004 15:42 Go to next message
Originally posted by: ricardo.qualiti.com.br
I need a plugin that opens a file in a eclipse java editor given its file
path. Does anybody know anything about it? Thanks (sorry if I posted the
question in the wrong forum... I didnt know the right one...)
Re: Plugin to open java files into eclipse [message #209179 is a reply to message #209126] Wed, 10 March 2004 17:00 Go to previous messageGo to next message
If you are asking what I think you are asking you do not need any sort of
plugin for this. You just need to associate your *.java files with the
appropriate eclipse editor and they will open in that editor.
If you go to:
Window->Preferences->(expand)Workbench->File Associations
then you can add *.java and choose the Java Editor as the associated
editor.
I hope this helps. If you are talking about doing something different then
I applogize.
Re: Plugin to open java files into eclipse [message #209784 is a reply to message #209126] Thu, 11 March 2004 11:54 Go to previous message
If you're talking about opening java files that are not in an Eclipse
Project, there is a plug-in that will provide this feature. Check the
www.eclipse-plugins.info site for it - I don't remember the name.
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Previous Topic:org.osgi.framework.BundleActivator
Next Topic:doc partitions for XML multi line comment blocks
Current Time: Tue Jul 22 02:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.23768 seconds
