Home » Eclipse Projects » Subversive » How to attach Subversive to an externally checked out working copy?
How to attach Subversive to an externally checked out working copy? [message #20211] Wed, 04 June 2008 05:39 Go to next message
I have a script that setups my local development environment which
includes checking out the code. When I create a project in Eclipse and
have it point the directory created by my script, it is not seen as svn
working copy. How do I get Subversive to connect to it?
Re: How to attach Subversive to an externally checked out working copy? [message #20216 is a reply to message #20211] Fri, 06 June 2008 03:46 Go to previous messageGo to next message
Hi Chris,
we also check-out using a manual script and if you use Maven which generates the Eclipse .project
this is also the usual way.
In my experience, it is sufficient to open the view "SVN Repository Exploring" and add your SVN
repository. Then, File/Import/Existing Projects into Workspace should do the job.
Any comments from the Subversive developers? Is this the expected way?
Chris, please feel free to ask further questions.
Cheers, Jörg
Re: How to attach Subversive to an externally checked out working copy? [message #20669 is a reply to message #20216] Mon, 09 June 2008 12:48 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hello Jörg, Chris,
Latest Subversive versions will not require manual repository locations
creating. So, the only thing to do is to import the projects into
workspace.
P.S.
Before importing please check that SVN connector selected in plug-in
preferences is compatible with the working copy format of projects to be
imported.
Previous Topic:Lines of code in a commit
Next Topic:Newby: Linux Connector
Current Time: Wed Nov 05 08:51:24 EST 2025
Powered by FUDForum. Page generated in 0.04420 seconds
