Home » Eclipse Projects » Eclipse Platform » XML Compare: gets exceptions?
XML Compare: gets exceptions? [message #209106] Wed, 10 March 2004 14:48 Go to next message
Is the XML Compare plugin working for anyone in 3.0 M7? When I
compare XML documents I get (Can't Compare Structures) in the XML
Compare window and if I look in the log file I have the backtrace
below. Before I posted a bug I wanted to know if this was a UBD
configuration issue or a real problem.
Shane
!ENTRY org.eclipse.compare.examples.xml 4 4 Mar 10, 2004 11:41:01.936
!MESSAGE Internal Error
!STACK 0
org.eclipse.jface.text.Assert$AssertionFailedException: Assertion failed:
at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java :658)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:333)
at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl. java:448)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:345)
at org.eclipse.compare.examples.xml.XMLStructureCreator.getStru cture(XMLStructureCreator.java:572)
at org.eclipse.compare.structuremergeviewer.StructureDiffViewer .compareInputChanged(StructureDiffViewer.java:200)
at org.eclipse.compare.examples.xml.XMLStructureViewer.compareI nputChanged(XMLStructureViewer.java:219)
at org.eclipse.compare.structuremergeviewer.StructureDiffViewer .inputChanged(StructureDiffViewer.java:146)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:238)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1004)
at org.eclipse.compare.CompareViewerSwitchingPane.setInput(Comp areViewerSwitchingPane.java:302)
at org.eclipse.compare.CompareEditorInput.createContents(Compar eEditorInput.java:395)
at org.eclipse.compare.internal.CompareEditor.createPartControl (CompareEditor.java:160)
at org.eclipse.ui.internal.PartPane$1.run(PartPane.java:121)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:819)
at org.eclipse.core.runtime.Platform.run(Platform.java:493)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:117)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :224)
at org.eclipse.ui.internal.EditorWorkbook.createPage(EditorWork book.java:157)
at org.eclipse.ui.internal.EditorWorkbook.add(EditorWorkbook.ja va:98)
at org.eclipse.ui.internal.EditorArea.addEditor(EditorArea.java :57)
at org.eclipse.ui.internal.EditorPresentation.openEditor(Editor Presentation.java:351)
at org.eclipse.ui.internal.EditorManager$2.run(EditorManager.ja va:549)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
at org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:538)
at org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:634)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:437)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:425)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2099)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2042)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2029)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2024)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2007)
at org.eclipse.compare.internal.CompareUIPlugin.openCompareEdit or(CompareUIPlugin.java:328)
at org.eclipse.compare.CompareUI.openCompareEditorOnPage(Compar eUI.java:126)
at org.eclipse.compare.internal.CompareAction.run(CompareAction .java:36)
at org.eclipse.compare.internal.BaseCompareAction.run(BaseCompa reAction.java:26)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:273)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:536)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:420)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2029)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Re: XML Compare: gets exceptions? [message #209135 is a reply to message #209106] Wed, 10 March 2004 15:55 Go to previous messageGo to next message
Originally posted by: sylcheung.hotmail.com
I am having the same problem, but I don't know how to fix this.
> Shane
> !STACK 0
Re: XML Compare: gets exceptions? [message #227457 is a reply to message #209135] Tue, 13 April 2004 07:26 Go to previous message
Originally posted by: Andre_Weinand.oti.com
On 10.3.2004 22:55 Uhr, in article 404F80B1.6090206@hotmail.com, "Samuel
>> Shane
>> !STACK 0
>> at
>> eCreator.java:572)
>> at
>> at
>> at
>> at
>> 4)
>> at
>> gPane.java:302)
>> at
>> :395)
>> at
>> va:160)
>> at
>> 819)
>> at
>> :351)
>> at
>> at
>> 34)
>> at
>> java:437)
>> at
>> at
>> n.java:328)
>> at
>> at
>> at
>> em.java:488)
>> at
>> ionItem.java:420)
>> at
>> at
>> ava:257)
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> java:25)
Please file a bug report.
--andre
Previous Topic:XML Compare
Next Topic:Ignored Resources in a folder
Current Time: Tue Nov 11 09:07:35 EST 2025
Powered by FUDForum. Page generated in 0.03596 seconds
