Home » Language IDEs » C / C++ IDE (CDT) » GDB options
GDB options [message #208912] Wed, 30 January 2008 11:50 Go to next message
When Im debugging my C program, quite often gdb can't evaluate variables
values and displays "No symbol xx in current context". I would like to
ask you which are the "correct" gcc options for a accurate debugging.
Tex.
Re: GDB options [message #209120 is a reply to message #208912] Mon, 04 February 2008 12:38 Go to previous messageGo to next message
Originally posted by: jim.marshall.wbemsolutions.com
Tex-Twil wrote:
> Hello,
> Thanks
> Tex.
The only option you should need is the "-g" option. Are your sources
compiled with optimizations turned on (-Ox)? If so the variable may be
optimized away. Or are you possibly referring to a macro?
Re: GDB options [message #209153 is a reply to message #209120] Tue, 05 February 2008 06:14 Go to previous messageGo to next message
the -g param inproves the debugger behavior, thanks.
Tex
Jim Marshall wrote:
> Tex-Twil wrote:
>> Hello,
>> Thanks
>> Tex.
Re: GDB options [message #209189 is a reply to message #209153] Tue, 05 February 2008 07:33 Go to previous messageGo to next message
.... but I still have the "No symbol xx in current context" on some
variables. The strange thing is that those variables are correctly
displayed the the "Variables" debug window.
cheers,
Tex
Tex-Twil wrote:
> Tex
> Jim Marshall wrote:
>> Tex-Twil wrote:
>>> Hello,
>>> Thanks
>>> Tex.
Re: GDB options [message #209203 is a reply to message #209189] Tue, 05 February 2008 16:09 Go to previous message
We would need more info on what you are referring to.
> cheers,
> Tex
Previous Topic:How to get unique documents for multiple editors editing the same file?
Next Topic:entire .cpp file when I clink on a function in the outline?
Current Time: Mon Nov 03 03:17:27 EST 2025
Powered by FUDForum. Page generated in 0.05073 seconds
