Home » Language IDEs » C / C++ IDE (CDT) » cygwin debugger path mapping
cygwin debugger path mapping [message #208836] Wed, 30 January 2008 04:42 Go to next message
Originally posted by: hilal.arslan.bte.mam.gov.tr
I've been using cygwin for my c++ projects in eclipse. When I try to debug
it says
Warning: /cygdrive/c/workspace/nnn/src: No such file or directory
I've installed cygwin on d: drive
and when I write mount on the cygwin bash below is the output.
$ mount
D\cygwin\bin on /usr/bin type system (binmode)
D\cygwin\lib on /usr/lib type system (binmode)
D\cygwin on / type system (binmode)
D\tmp on / type system (binmode)
c: on /cygdrive/c type system (binmode,noumount)
d: on /cygdrive/d type system (binmode,noumount)
e: on /cygdrive/e type system (binmode,noumount)
k: on /cygdrive/k type system (binmode,noumount)
m: on /cygdrive/m type system (binmode,noumount)
o: on /cygdrive/o type system (binmode,noumount)
and when I open the bash
it prompts me from
c:\Documents And Settings\hilal
I've searched on internet and saw path mappings
From the source look up path
I added a path mapping.(My eclipse workspace is c:\workspace)
\\cygdrive\c-c:\
it didn't work
\\cygdrive\c\workspace\nnn\src-c:\workspace\nnn\src
it didn't work either.
can u help me with this?
Re: cygwin debugger path mapping [message #208870 is a reply to message #208836] Wed, 30 January 2008 09:14 Go to previous messageGo to next message
Hi Hilal,
This might not be a direct solution but you might try to use mingw32 if
you don't have to use cygwin.
Burak
> debug it says
> $ mount
> it prompts me from c:\Documents And Settings\hilal
> From the source look up path I added a path mapping.(My eclipse
> \\cygdrive\c-c:\
> it didn't work
Re: cygwin debugger path mapping [message #209058 is a reply to message #208836] Sun, 03 February 2008 06:19 Go to previous message
Instead of \\cygdrive\c try \cygdrive\c\
"Hilal" <hilal.arslan@bte.mam.gov.tr> wrote in message
news:073550c29a75909c5f60eb718b9a0b72$1@www.eclipse.org...
> it says
> $ mount
> From the source look up path I added a path mapping.(My eclipse workspace
> is c:\workspace)
> \\cygdrive\c-c:\
> it didn't work
Previous Topic:Managed C++ Projects: figments of my imagination?
Next Topic:"Project" containing several libs and one executable
Current Time: Sat Jul 26 09:27:37 EDT 2025
Powered by FUDForum. Page generated in 0.04481 seconds
