Home » Eclipse Projects » Eclipse Platform » Cannot find class JavaDocAccess
Cannot find class JavaDocAccess [message #208699] Wed, 10 March 2004 04:30 Go to next message
Originally posted by: u.clement.exxcellent.de
hi there,
while using eclipse 3.0 M6 i was able to use the class:
import org.eclipse.jdt.internal.corext.javadoc.JavaDocAccess
after changing to eclipse 3.0 m7 the compiler cannot find this file
anymore.
why is it like that ?!
thanks in advance.
best regards
uwe clement
Re: Cannot find class JavaDocAccess [message #208804 is a reply to message #208699] Wed, 10 March 2004 08:12 Go to previous messageGo to next message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Wed, 10 Mar 2004 09:30:57 +0000 (UTC), u.clement@exxcellent.de (Uwe
This class is in an internal package.
It can be changed or removed without notice as it is not API.
Never reference such a class.
Olivier
Re: Cannot find class JavaDocAccess [message #208825 is a reply to message #208699] Wed, 10 March 2004 08:17 Go to previous message
Originally posted by: daniel.megert.gmx.net
Uwe Clement wrote:
>hi there,
>anymore.
The class is still here. Probably a Java build path problem on your side.
Dani
>thanks in advance.
>best regards
>uwe clement
Previous Topic:Eclipse under linux looks bad...
Next Topic:R3.0 Platform UI summary of comments and response for post M7 UI changes
Current Time: Sun Nov 30 08:32:05 EST 2025
Powered by FUDForum. Page generated in 0.03988 seconds
