| Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #20089] |
Sun, 04 May 2003 05:09  |
Originally posted by: dirk.schesmer.divos.de
Hi there,
when trying to execute XSDFindTypesMissingFacets.java in the Eclipse 2.1
using the environment emf/xsd 1.1.0, the system reports thje errors printed
below. Can please anyone give me a hint what to do?
Thanks for help,
Dirk V. Schesmer
Shane, please try to update the compile parameters - especially names ans
locations of jars - when you have some time left over, thanks!
* <br/>set ECLIPSE=BASEDIR
* <br/>set
_CP=%CLASSPATH%;%ECLIPSE%/plugins/org.eclipse.core.boot/boot .jar;%
ECLIPSE%/plugins/org.eclipse.core.runtime/runtime.jar;%ECLIP SE%/plugins/org.
apache.xerces/xerces.jar;%ECLIPSE%/plugins/org.eclipse.core. resources/resour
ces.jar;%ECLIPSE%/plugins/org.eclipse.emf/emf.jar;%ECLIPSE%/ plugins/org.ecli
pse.xsd/xsd.jar;path-or-jar-containing-XSDFindTypesMissingFa cet
* <br/>java -classpath %_CP% -DECLIPSE=%ECLIPSE%
org.eclipse.xsd.util.XSDFindTypesMissingFacet [schema.xsd]
* </code>
* </p>
The error message produced when executing the software in Eclipe 2.1:
java.lang.VerifyError: (class: org/eclipse/xsd/util/XSDParser$2, method:
xmlDecl signature:
(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/ apache/xerces/xn
i/Augmentations;)V) Illegal use of nonvirtual function call
at org.eclipse.xsd.util.XSDParser$1.<init>(XSDParser.java:206)
org.eclipse.xsd.util.XSDParser$1$GiantHack.newSAXParser(XSDP arser.java:197)
at org.eclipse.xsd.util.XSDParser.<init>(XSDParser.java:386)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:282)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetIm
pl.java:220)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
mpl.java:286)
org.eclipse.xsd.util.XSDFindTypesMissingFacets.loadSchemaUsi ngResourceSet(Un
known Source)
at org.eclipse.xsd.util.XSDFindTypesMissingFacets.main(Unknown Source)
Exception in thread "main"
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #21046 is a reply to message #20089] |
Sun, 04 May 2003 07:20   |
--------------9FB854F7C854B0D327584658
Content-Type: text/plain; charset=us-ascii
Dirk,
This looks like the error one would get if the right xerces jars aren't the
classpath. The file plugins/org.eclipse.xsd.test/test/xsd-standalone-test.bat
is maintained with the classpath required for standalone execution. These two
are needed:
%ECLIPSE%/plugins/org.apache.xerces_4.0.7/xmlParserAPIs.jar;
%ECLIPSE%/plugins/org.apache.xerces_4.0.7/xercesImpl.jar;
"Dirk V. Schesmer" wrote:
> Hi there,
> Thanks for help,
> Dirk V. Schesmer
> * <br/>set
> * </code>
> * </p>
> xmlDecl signature:
> at
> at
> at
> at
> pl.java:220)
> at
> mpl.java:286)
> at
> known Source)
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Dirk,
<p>This looks like the error one would get if the right xerces jars aren't
the classpath. The file plugins/org.eclipse.xsd.test/test/xsd-standalone-test.bat
These two are needed:
<blockquote> %ECLIPSE%/plugins/org.apache.xerces_4.0.7/xmlParserAPIs.jar;
<br>%ECLIPSE%/plugins/org.apache.xerces_4.0.7/xercesImpl.jar; </blockquote>
<p><br>"Dirk V. Schesmer" wrote:
<blockquote TYPE=CITE>Hi there,
<p>when trying to execute XSDFindTypesMissingFacets.java in the Eclipse
2.1
<br>using the environment emf/xsd 1.1.0, the system reports thje errors
printed
<br>below. Can please anyone give me a hint what to do?
<p>Thanks for help,
<p>Dirk V. Schesmer
<p>Shane, please try to update the compile parameters - especially names
ans
<br>locations of jars - when you have some time left over, thanks!
<p>* <br/>set ECLIPSE=BASEDIR
<br>* <br/>set
<br> _CP=%CLASSPATH%;%ECLIPSE%/plugins/org.eclipse.core.boot/boot .jar;%
<br> ECLIPSE%/plugins/org.eclipse.core.runtime/runtime.jar;%ECLIP SE%/plugins/org.
<br> apache.xerces/xerces.jar;%ECLIPSE%/plugins/org.eclipse.core. resources/resour
<br> ces.jar;%ECLIPSE%/plugins/org.eclipse.emf/emf.jar;%ECLIPSE%/ plugins/org.ecli
<br> pse.xsd/xsd.jar;path-or-jar-containing-XSDFindTypesMissingFa cet
<br>* <br/>java -classpath %_CP% -DECLIPSE=%ECLIPSE%
<br>org.eclipse.xsd.util.XSDFindTypesMissingFacet [schema.xsd]
<br>* </code>
<br>* </p>
<p>The error message produced when executing the software in Eclipe 2.1:
<p>java.lang.VerifyError: (class: org/eclipse/xsd/util/XSDParser$2, method:
<br>xmlDecl signature:
<br> (Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/ apache/xerces/xn
<br>i/Augmentations;)V) Illegal use of nonvirtual function call
<p>at org.eclipse.xsd.util.XSDParser$1.<init>(XSDParser.java:206)
<p>at
<br> org.eclipse.xsd.util.XSDParser$1$GiantHack.newSAXParser(XSDP arser.java:197)
<p>at org.eclipse.xsd.util.XSDParser.<init>(XSDParser.java:386)
<p>at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:282)
<p>at
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
<p>at
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
<p>at
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetIm
<br>pl.java:220)
<p>at
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
<br>mpl.java:286)
<p>at
<br> org.eclipse.xsd.util.XSDFindTypesMissingFacets.loadSchemaUsi ngResourceSet(Un
<br>known Source)
<p>at org.eclipse.xsd.util.XSDFindTypesMissingFacets.main(Unknown Source)
<p>Exception in thread "main"</blockquote>
</html>
--------------9FB854F7C854B0D327584658--
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #21313 is a reply to message #21046] |
Mon, 05 May 2003 14:41  |
I'd agree with Ed; suspect a Xerces version-mismatch first of all. Unless
of course it's just an error in the GiantHack class; I can't comment on
that one (at least not with a straight face!).
Also I'm not sure which specific file you're referring to - oh, wait: do
you mean the XSDFindTypesMissingFacet.java file in the current CVS tree's
Javadoc? I've already updated the example .bat files in my online article
to use %_XERCESVER% as a parameter for the version number in the path,
since it's been changing lately.
- Shane
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #569729 is a reply to message #20089] |
Dirk,
are needed:
> Hi there,
> Thanks for help,
> Dirk V. Schesmer
> * <br/>set
> * </code>
> * </p>
> xmlDecl signature:
> at
> at
> at
> at
> pl.java:220)
> at
> mpl.java:286)
> at
> known Source)
<html>
Dirk,
2.1
printed
<p>Thanks for help,
<p>Dirk V. Schesmer
ans
<br>* <br/>set
<br>* </code>
<br>* </p>
<p>at
<p>at
<p>at
<p>at
<br>pl.java:220)
<p>at
<br>mpl.java:286)
<p>at
<br>known Source)
</html>
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #570601 is a reply to message #21046] |
- Shane
FUDForum. Page generated in 0.04421 seconds
