| Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #20089] | Sun, 04 May 2003 05:09  |  |
| Eclipse User  |  |  |  |  | Originally posted by: dirk.schesmer.divos.de
 Hi there,
 when trying to execute XSDFindTypesMissingFacets.java in the Eclipse 2.1
 using the environment emf/xsd 1.1.0, the system reports thje errors printed
 below. Can please anyone give me a hint  what to do?
 Thanks for help,
 Dirk V. Schesmer
 Shane, please try to update the compile parameters - especially names ans
 locations of jars - when you have some time left over, thanks!
 * <br/>set ECLIPSE=BASEDIR
 * <br/>set
 _CP=%CLASSPATH%;%ECLIPSE%/plugins/org.eclipse.core.boot/boot .jar;%
 ECLIPSE%/plugins/org.eclipse.core.runtime/runtime.jar;%ECLIP SE%/plugins/org.
 apache.xerces/xerces.jar;%ECLIPSE%/plugins/org.eclipse.core. resources/resour
 ces.jar;%ECLIPSE%/plugins/org.eclipse.emf/emf.jar;%ECLIPSE%/ plugins/org.ecli
 pse.xsd/xsd.jar;path-or-jar-containing-XSDFindTypesMissingFa cet
 * <br/>java -classpath %_CP% -DECLIPSE=%ECLIPSE%
 org.eclipse.xsd.util.XSDFindTypesMissingFacet [schema.xsd]
 * </code>
 * </p>
 The error message produced when executing the software in Eclipe 2.1:
 java.lang.VerifyError: (class: org/eclipse/xsd/util/XSDParser$2, method:
 xmlDecl signature:
 (Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/ apache/xerces/xn
 i/Augmentations;)V) Illegal use of nonvirtual function call
 at org.eclipse.xsd.util.XSDParser$1.<init>(XSDParser.java:206)
 org.eclipse.xsd.util.XSDParser$1$GiantHack.newSAXParser(XSDP arser.java:197)
 at org.eclipse.xsd.util.XSDParser.<init>(XSDParser.java:386)
 at  org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:282)
 org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
 org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
 org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetIm
 pl.java:220)
 org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
 mpl.java:286)
 org.eclipse.xsd.util.XSDFindTypesMissingFacets.loadSchemaUsi ngResourceSet(Un
 known Source)
 at org.eclipse.xsd.util.XSDFindTypesMissingFacets.main(Unknown Source)
 Exception in thread "main"
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #21046 is a reply to message #20089] | Sun, 04 May 2003 07:20   |  |
| Eclipse User  |  |  |  |  | Originally posted by: merks.ca.ibm.com
 --------------9FB854F7C854B0D327584658
 Content-Type: text/plain; charset=us-ascii
 Dirk,
 This looks like the error one would get if the right xerces jars aren't the
 classpath.  The file plugins/org.eclipse.xsd.test/test/xsd-standalone-test.bat
 is maintained with the classpath required for standalone execution.  These two
 are needed:
 %ECLIPSE%/plugins/org.apache.xerces_4.0.7/xmlParserAPIs.jar;
 %ECLIPSE%/plugins/org.apache.xerces_4.0.7/xercesImpl.jar;
 "Dirk V. Schesmer" wrote:
 > Hi there,
 > Thanks for help,
 > Dirk V. Schesmer
 > * <br/>set
 > * </code>
 > * </p>
 > xmlDecl signature:
 > at
 > at
 > at
 > at
 > pl.java:220)
 > at
 > mpl.java:286)
 > at
 > known Source)
 Content-Type: text/html; charset=us-ascii
 <!doctype html public "-//w3c//dtd html 4.0 transitional//en">
 <html>
 Dirk,
 <p>This looks like the error one would get if the right xerces jars aren't
 the classpath.  The file plugins/org.eclipse.xsd.test/test/xsd-standalone-test.bat
 These two are needed:
 <blockquote> %ECLIPSE%/plugins/org.apache.xerces_4.0.7/xmlParserAPIs.jar;
 <br>%ECLIPSE%/plugins/org.apache.xerces_4.0.7/xercesImpl.jar; </blockquote>
 <p><br>"Dirk V. Schesmer" wrote:
 <blockquote TYPE=CITE>Hi there,
 <p>when trying to execute XSDFindTypesMissingFacets.java in the Eclipse
 2.1
 <br>using the environment emf/xsd 1.1.0, the system reports thje errors
 printed
 <br>below. Can please anyone give me a hint  what to do?
 <p>Thanks for help,
 <p>Dirk V. Schesmer
 <p>Shane, please try to update the compile parameters - especially names
 ans
 <br>locations of jars - when you have some time left over, thanks!
 <p>* <br/>set ECLIPSE=BASEDIR
 <br>* <br/>set
 <br> _CP=%CLASSPATH%;%ECLIPSE%/plugins/org.eclipse.core.boot/boot .jar;%
 <br> ECLIPSE%/plugins/org.eclipse.core.runtime/runtime.jar;%ECLIP SE%/plugins/org.
 <br> apache.xerces/xerces.jar;%ECLIPSE%/plugins/org.eclipse.core. resources/resour
 <br> ces.jar;%ECLIPSE%/plugins/org.eclipse.emf/emf.jar;%ECLIPSE%/ plugins/org.ecli
 <br> pse.xsd/xsd.jar;path-or-jar-containing-XSDFindTypesMissingFa cet
 <br>* <br/>java -classpath %_CP% -DECLIPSE=%ECLIPSE%
 <br>org.eclipse.xsd.util.XSDFindTypesMissingFacet [schema.xsd]
 <br>* </code>
 <br>* </p>
 <p>The error message produced when executing the software in Eclipe 2.1:
 <p>java.lang.VerifyError: (class: org/eclipse/xsd/util/XSDParser$2, method:
 <br>xmlDecl signature:
 <br> (Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/ apache/xerces/xn
 <br>i/Augmentations;)V) Illegal use of nonvirtual function call
 <p>at org.eclipse.xsd.util.XSDParser$1.<init>(XSDParser.java:206)
 <p>at
 <br> org.eclipse.xsd.util.XSDParser$1$GiantHack.newSAXParser(XSDP arser.java:197)
 <p>at org.eclipse.xsd.util.XSDParser.<init>(XSDParser.java:386)
 <p>at  org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:282)
 <p>at
 <br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
 <p>at
 <br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
 <p>at
 <br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetIm
 <br>pl.java:220)
 <p>at
 <br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
 <br>mpl.java:286)
 <p>at
 <br> org.eclipse.xsd.util.XSDFindTypesMissingFacets.loadSchemaUsi ngResourceSet(Un
 <br>known Source)
 <p>at org.eclipse.xsd.util.XSDFindTypesMissingFacets.main(Unknown Source)
 <p>Exception in thread "main"</blockquote>
 </html>
 --------------9FB854F7C854B0D327584658--
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #21313 is a reply to message #21046] | Mon, 05 May 2003 14:41  |  |
| Eclipse User  |  |  |  |  | I'd agree with Ed; suspect a Xerces version-mismatch first of all.  Unless of course it's just an error in the GiantHack class; I can't comment on
 that one (at least not with a straight face!).
 Also I'm not sure which specific file you're referring to - oh, wait: do
 you mean the XSDFindTypesMissingFacet.java file in the current CVS tree's
 Javadoc?  I've already updated the example .bat files in my online article
 to use %_XERCESVER% as a parameter for the version number in the path,
 since it's been changing lately.
 - Shane
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #569729 is a reply to message #20089] | Sun, 04 May 2003 07:20  |  |
| Eclipse User  |  |  |  |  | --------------9FB854F7C854B0D327584658 Content-Type: text/plain; charset=us-ascii
 Dirk,
 are needed:
 > Hi there,
 > Thanks for help,
 > Dirk V. Schesmer
 > * <br/>set
 > * </code>
 > * </p>
 > xmlDecl signature:
 > at
 > at
 > at
 > at
 > pl.java:220)
 > at
 > mpl.java:286)
 > at
 > known Source)
 <html>
 Dirk,
 2.1
 printed
 <p>Thanks for help,
 <p>Dirk V. Schesmer
 ans
 <br>* <br/>set
 <br>* </code>
 <br>* </p>
 <p>at
 <p>at
 <p>at
 <p>at
 <br>pl.java:220)
 <p>at
 <br>mpl.java:286)
 <p>at
 <br>known Source)
 </html>
| Re: Cannot run XSDFindTypesMissingFacets in V1.1.0 [message #570601 is a reply to message #21046] | Mon, 05 May 2003 14:41  |  |
 - Shane
FUDForum. Page generated in 0.71449 seconds
