Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem with p2 and version qualifiers
Problem with p2 and version qualifiers [message #20085] Sat, 06 September 2008 23:27 Go to next message
Originally posted by: wbeckwith.gmail.com
I'm build a feature and I have the follwoignp2 properties defined in the
builder's build.properties file:
# P2 Properties
generate.p2.metadata = true
p2.metadata.repo.name = ${itko.repo.name}
p2.metadata.repo = ${itko.repo}
p2.artifact.repo.name = ${itko.repo.name}
p2.artifact.repo = ${itko.repo}
p2.flavor = tooling
p2.publish.artifacts = true
p2.root.name = iTKO Lisa
p2.root.version = 1.0.0.qualifier
When doing the build my plug-ins and features with a version of
1.0.0.qualifier will get the "qualifier" substituted during the build,
but the p2.root.version property does not and always ends up as
1.0.0.qualifier. How do I need to change things so that this is
dynamically updated during the build?
Wb
Re: Problem with p2 and version qualifiers [message #20351 is a reply to message #20085] Tue, 09 September 2008 14:40 Go to previous messageGo to next message
I'm setting quite some properties via: -Dproperty.name=property.value
when invoking pdeBuild.xml.
You could inject the qualifier in the same way.
-- Ketan
> # P2 Properties
> p2.flavor = tooling
> Wb
Re: Problem with p2 and version qualifiers [message #20381 is a reply to message #20351] Tue, 09 September 2008 14:54 Go to previous messageGo to next message
That's a suggestion/workaround if was to change the version from
1.0.0.qualifier to 1.0.0.${qualifier} and pass "-Dqualifer=myqualifier".
First I'd have to compute the qualifier and then inject it into the
pde build command invocation and 2nd pde build normally takes care of
this. PDE build is doing the right thing for the feature and plug-ins,
it just doesn't seem to be doing the right thing when building the p2
repo. So I'm trying to see if my setup is in error or if pde build has
a bug.
Wb
> -- Ketan
>> the builder's build.properties file:
>> # P2 Properties
>> p2.flavor = tooling
>> Wb
Re: Problem with p2 and version qualifiers [message #20398 is a reply to message #20381] Tue, 09 September 2008 15:43 Go to previous message
Wendell,
Unfortunately you will need to use the workaround for now. Build does
not currently have support to replace qualifiers that are used in the p2
calls.
There is https://bugs.eclipse.org/bugs/show_bug.cgi?id=246060 which is
related to this, I added a note there about p2.root.version.
If you are using a .product file and want the version replaced there,
there is a workaround in the example on my blog
( http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html).
-Andrew
> First I'd have to compute the qualifier and then inject it into the pde
> build command invocation and 2nd pde build normally takes care of this.
> PDE build is doing the right thing for the feature and plug-ins, it just
> doesn't seem to be doing the right thing when building the p2 repo. So
> I'm trying to see if my setup is in error or if pde build has a bug.
> Wb
>> -- Ketan
>>> # P2 Properties
>>> p2.flavor = tooling
>>> build, but the p2.root.version property does not and always ends up
>>> as 1.0.0.qualifier. How do I need to change things so that this is
>>> Wb
Re: Problem with p2 and version qualifiers [message #579327 is a reply to message #20085] Tue, 09 September 2008 14:40 Go to previous message
-- Ketan
> # P2 Properties
> p2.flavor = tooling
> Wb
Re: Problem with p2 and version qualifiers [message #579404 is a reply to message #20351] Tue, 09 September 2008 14:54 Go to previous message
a bug.
Wb
> -- Ketan
>> # P2 Properties
>> p2.flavor = tooling
>> Wb
Re: Problem with p2 and version qualifiers [message #579443 is a reply to message #20381] Tue, 09 September 2008 15:43 Go to previous message
Wendell,
calls.
-Andrew
> Wb
>> -- Ketan
>>> # P2 Properties
>>> p2.flavor = tooling
>>> Wb
Previous Topic:Why can't a plug-in see a fragment's additions?
Next Topic:How to specify <launcherIcons> in product.properties file
Current Time: Tue Nov 11 20:12:12 EST 2025
Powered by FUDForum. Page generated in 0.35266 seconds
