Problem with p2 and version qualifiers [message #20085] |
Sat, 06 September 2008 23:27  |
Originally posted by: wbeckwith.gmail.com
I'm build a feature and I have the follwoignp2 properties defined in the
builder's build.properties file:
# P2 Properties
generate.p2.metadata = true
p2.metadata.repo.name = ${itko.repo.name}
p2.metadata.repo = ${itko.repo}
p2.artifact.repo.name = ${itko.repo.name}
p2.artifact.repo = ${itko.repo}
p2.flavor = tooling
p2.publish.artifacts = true
p2.root.name = iTKO Lisa
p2.root.version = 1.0.0.qualifier
When doing the build my plug-ins and features with a version of
1.0.0.qualifier will get the "qualifier" substituted during the build,
but the p2.root.version property does not and always ends up as
1.0.0.qualifier. How do I need to change things so that this is
dynamically updated during the build?
Wb
Re: Problem with p2 and version qualifiers [message #20398 is a reply to message #20381] |
Tue, 09 September 2008 15:43  |
Wendell,
Unfortunately you will need to use the workaround for now. Build does
not currently have support to replace qualifiers that are used in the p2
calls.
There is https://bugs.eclipse.org/bugs/show_bug.cgi?id=246060 which is
related to this, I added a note there about p2.root.version.
If you are using a .product file and want the version replaced there,
there is a workaround in the example on my blog
( http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html).
-Andrew
Wendell Beckwith wrote:
> That's a suggestion/workaround if was to change the version from
> 1.0.0.qualifier to 1.0.0.${qualifier} and pass "-Dqualifer=myqualifier".
> First I'd have to compute the qualifier and then inject it into the pde
> build command invocation and 2nd pde build normally takes care of this.
> PDE build is doing the right thing for the feature and plug-ins, it just
> doesn't seem to be doing the right thing when building the p2 repo. So
> I'm trying to see if my setup is in error or if pde build has a bug.
> Wb
> Ketan Padegaonkar wrote:
>> I'm setting quite some properties via: -Dproperty.name=property.value
>> when invoking pdeBuild.xml.
>> You could inject the qualifier in the same way.
>> -- Ketan
>>> the builder's build.properties file:
>>> # P2 Properties
>>> p2.flavor = tooling
>>> build, but the p2.root.version property does not and always ends up
>>> as 1.0.0.qualifier. How do I need to change things so that this is
>>> Wb
Re: Problem with p2 and version qualifiers [message #579327 is a reply to message #20085] |
Tue, 09 September 2008 14:40  |
-- Ketan
> # P2 Properties
> p2.flavor = tooling
> Wb
Re: Problem with p2 and version qualifiers [message #579404 is a reply to message #20351] |
Tue, 09 September 2008 14:54  |
pde build command invocation and 2nd pde build normally takes care of
this. PDE build is doing the right thing for the feature and plug-ins,
it just doesn't seem to be doing the right thing when building the p2
repo. So I'm trying to see if my setup is in error or if pde build has
a bug.
Wb
> -- Ketan
>> # P2 Properties
>> p2.flavor = tooling
>> Wb
Re: Problem with p2 and version qualifiers [message #579443 is a reply to message #20381] |
Wendell,
calls.
-Andrew
> Wb
>> -- Ketan
>>> # P2 Properties
>>> p2.flavor = tooling
>>> Wb
FUDForum. Page generated in 0.70703 seconds
