Home » Language IDEs » Java Development Tools (JDT) » Using the ASTParser to parse .class files.
Using the ASTParser to parse .class files. [message #207917] Sat, 25 June 2005 21:10 Go to next message
Originally posted by: clarkep.fiu.edu
If you want to parse a .class file using the ASTParser do you first have
to implement the IClassFile? Parsing the source .java text file is not
a problem only the .class file. Also can the parsing of .class files be
done outside of the Eclipse environment?
Peter.
Re: Using the ASTParser to parse .class files. [message #207958 is a reply to message #207917] Sun, 26 June 2005 10:27 Go to previous messageGo to next message
Using an ASTParser should be used only to parse source code. The
setSource(IClassFile) works only if the IClassFile has an attached source.
If you want to get information about a .class file, you might want to
look at the org.eclipse.jdt.core.util.IClassFileReader API.
Olivier
Re: Using the ASTParser to parse .class files. [message #207966 is a reply to message #207958] Sun, 26 June 2005 16:43 Go to previous message
Originally posted by: clarkepeter.bellsouth.net
Olivier,
Thank you very much.
Peter.
> Olivier
Previous Topic:Cheetah and RC3
Next Topic:Repost: Original source element of working copy in ElementChangedListener
Current Time: Sun Aug 31 19:52:35 EDT 2025
Powered by FUDForum. Page generated in 0.02868 seconds
