How to change the target server after creating a Dynamic Web Project? [message #207653] |
Tue, 29 January 2008 10:57  |
I created a "Dynamic Web Project" using Apache Tomcat 6.0. Now I need to
change this project to run on Tomcat 5.5. How do I do that?
When I want to change Window => Pref's => Targeted Runtimes then only
Tomcat 6.0 is listed. If I check "Show all runtimes" I see Tomcat 5.5
but it is grayed/deactivated, i.e. I can not select it. The
When I right-click the project and select Run... => Run On Server... I
get a list containing both servers, but if I select Tomcat 5.5 here then
I get an error "The server does not support version 2.5 of the J2EE Web
module specification".
When I right-click the project and select Properties => Project Facets
I see "Dynamic Web Module version: 2.5". If I click the Modify
Project... button I get a dialog "Modify Project Facets". If I select
Dynamic Web Module => Version 2.4 here I get an error telling me "Cannot
change version of project facet Dynamic Web Module to 2.4".
So, how the heck do I change the target platform for this project such
that I can run it on Tomcat 5.5???
Michael
Re: How to change the target server after creating a Dynamic Web Project? [message #207759 is a reply to message #207694] |
Wed, 30 January 2008 05:58   |
------=_NextPart_000_0019_01C86337.758216B0
Content-Type: text/plain;
charset="iso-8859-1"
Hi Larry,
I considered your procedure a bit tedious and so I decided to set things =
straight "manually". Just in case anybody has to do the same ever - here =
is what I had to do:
In .classpath I changed:
<classpathentry exported=3D"true" kind=3D"con" =
path=3D" org.eclipse.jst.server.core.container/org.eclipse.jst.server .tomc=
at.runtimeTarget/Apache Tomcat v6.0"/>
to:
at.runtimeTarget/Apache Tomcat v5.5"/>
=20
In .settings/org.eclipse.jst.common.project.facet.core. I changed:
classpath.helper/org.eclipse.jst.server.core.container\:\:or g.eclipse.jst=
..server.tomcat.runtimeTarget\:\:Apache\ Tomcat\ =
v6.0/owners=3Djst.web\:2.5
to:
v5.5/owners=3Djst.web\:2.4
And in .settings/org.eclipse.wst.common.project.facet.core.xml I =
changed:
<runtime name=3D"Apache Tomcat v6.0"/>
<installed facet=3D"jst.web" version=3D"2.5"/>
to:
<runtime name=3D"Apache Tomcat v5.5"/>
<installed facet=3D"jst.web" version=3D"2.4"/>
I am not sure whether ALL of these changes are really necessary, but I =
changed them all for consistency.
After that the project turned out to "Tomcat 5.5 compliant"!
Michael
Larry Isaacs wrote:
> I don't believe the "Dynamic Web Module" facet supports modification.
> Since your current project specifies "2.5", you won't be able to set
> the target runtime or deploy to Tomcat 5.5 since it only supports up
> through version "2.4". I would recommend creating a new project with
> "2.4" as the "Dynamic Web Module" facet, which choosing the Tomcat
> 5.5 runtime would accomplish. If you plan to deploy on either, make
> sure the Java facet is set for the lower of the versions your Tomcat
> 5.5 and Tomcat=20
> 6.0 are running with, if there happens to be a difference. Then copy
> the content from the old project to the new one and port any web.xml
> changes necessary.
>=20
> Cheers,
> Larry
Content-Type: text/html;
<HTML><HEAD><LINK href=3D"C:\Program Files\OE-QuoteFix\styles.css" =
rel=3Dstylesheet>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16595" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><SPAN class=3Dq0>Hi Larry,</SPAN></DIV>
<DIV><SPAN class=3Dq0>I considered your procedure a bit tedious and so I =
decided=20
to set things straight "manually". </SPAN><SPAN class=3Dq0>Just in case =
anybody=20
has to do the same ever - h</SPAN><SPAN class=3Dq0>ere is what I had to=20
do:</SPAN></DIV>
<DIV><SPAN class=3Dq0></SPAN> </DIV>
<DIV><SPAN class=3Dq0>In .classpath I changed:</SPAN></DIV>
<DIV><FONT color=3D#008080 size=3D2><</FONT><FONT color=3D#3f7f7f=20
size=3D2>classpathentry </FONT><FONT color=3D#7f007f =
size=3D2>exported</FONT><FONT=20
size=3D2>=3D</FONT><FONT color=3D#2a00ff size=3D2>"true" </FONT><FONT =
color=3D#7f007f=20
size=3D2>kind</FONT><FONT size=3D2>=3D</FONT><FONT color=3D#2a00ff =
size=3D2>"con"=20
</FONT><FONT color=3D#7f007f size=3D2>path</FONT><FONT =
size=3D2>=3D</FONT><FONT=20
color=3D#2a00ff=20
size=3D2>" org.eclipse.jst.server.core.container/org.eclipse.jst.server .to=
mcat.runtimeTarget/Apache=20
Tomcat v6.0"</FONT><FONT color=3D#008080 size=3D2>/></FONT></DIV>
<DIV><SPAN class=3Dq0>to:</SPAN></DIV></DIV></FONT></SPAN></DIV>
color=3D#7f007f=20
size=3D2>"con"=20
color=3D#2a00ff=20
Tomcat v5.5"</FONT><FONT color=3D#008080 size=3D2>/></DIV></FONT>
<DIV><SPAN class=3Dq0><SPAN class=3Dq0> </DIV>
<DIV>
<DIV><SPAN=20
class=3Dq0>In </SPAN>.settings/org.eclipse.jst.common.project.facet.=
core. I=20
changed:<BR><FONT=20
size=3D2>classpath.helper/org.eclipse.jst.server.core.container\: </FONT><=
FONT=20
color=3D#2a00ff=20
size=3D2>\:org.eclipse.jst.server.tomcat.runtimeTarget\:\:Apache\ </FONT><=
FONT=20
size=3D2> </FONT><FONT color=3D#2a00ff size=3D2>Tomcat\</FONT><FONT =
size=3D2>=20
</FONT><FONT color=3D#2a00ff size=3D2>v6.0/owners</FONT><FONT =
color=3D#2a00ff size=3D2>jst.web\:2.5<BR></FONT></SPAN></SPAN><SPAN =
class=3Dq0><SPAN=20
class=3Dq0><FONT size=3D2>to:</FONT><BR><FONT=20
size=3D2>classpath.helper/org.eclipse.jst.server.core.container\: <FONT=20
color=3D#2a00ff>\:org.eclipse.jst.server.tomcat.runtimeTarget\:\:Apache\ <=
/FONT>=20
<FONT color=3D#2a00ff>Tomcat\</FONT> <FONT=20
color=3D#2a00ff>v5.5/owners</FONT>=3D</FONT><FONT color=3D#2a00ff=20
size=3D2>jst.web\:2.4</FONT></SPAN></SPAN></DIV>
<P><SPAN class=3Dq0><SPAN class=3Dq0><SPAN class=3Dq0>And=20
in </SPAN>.settings/org.eclipse.wst.common.project.facet.core.xml I =
changed:<BR></SPAN></SPAN><SPAN class=3Dq0><FONT size=3D2><FONT =
color=3D#008080=20
size=3D2><</FONT><FONT color=3D#3f7f7f size=3D2>runtime </FONT><FONT =
color=3D#7f007f=20
size=3D2>name</FONT><FONT size=3D2>=3D</FONT><FONT color=3D#2a00ff =
size=3D2>"Apache Tomcat=20
v6.0"</FONT><FONT color=3D#008080 size=3D2>/><BR></FONT><FONT =
color=3D#008080=20
size=3D2>...<BR></FONT><FONT color=3D#008080 size=3D2><</FONT><FONT =
color=3D#3f7f7f=20
size=3D2>installed </FONT><FONT color=3D#7f007f =
size=3D2>facet</FONT><FONT=20
size=3D2>=3D</FONT><FONT color=3D#2a00ff size=3D2>"jst.web" </FONT><FONT =
color=3D#7f007f=20
size=3D2>version</FONT><FONT size=3D2>=3D</FONT><FONT color=3D#2a00ff=20
size=3D2>"2.5"</FONT><FONT color=3D#008080 =
size=3D2>/><BR></FONT></FONT><FONT=20
color=3D#008080 size=3D2><SPAN class=3Dq0>to:<BR></SPAN><</FONT><FONT =
color=3D#3f7f7f=20
size=3D2>runtime </FONT><FONT color=3D#7f007f size=3D2>name</FONT><FONT=20
size=3D2>=3D</FONT><FONT color=3D#2a00ff size=3D2>"Apache Tomcat =
v5.5"</FONT><FONT=20
color=3D#008080 size=3D2>/><BR></FONT><FONT color=3D#008080=20
color=3D#3f7f7f=20
color=3D#7f007f=20
size=3D2>"2.4"</FONT><FONT color=3D#008080 =
size=3D2>/></P></DIV></FONT></SPAN>
<DIV><SPAN class=3Dq0>I am not sure whether ALL of these changes are =
really=20
necessary, but I changed them all for consistency.</SPAN></DIV>
<DIV><SPAN class=3Dq0>After that the project turned out to "Tomcat =
5.5=20
compliant"!</SPAN></DIV>
<DIV><SPAN class=3Dq0><FONT face=3DArial =
size=3D2></FONT></SPAN> </DIV>
<DIV><SPAN class=3Dq0>Michael</SPAN></DIV>
<DIV><SPAN class=3Dq0></SPAN><SPAN class=3Dq0></SPAN> </DIV>
<DIV><SPAN class=3Dq0>Larry Isaacs wrote:<BR></SPAN><SPAN =
class=3Dq1>> I don't=20
believe the "Dynamic Web Module" facet supports modification.<BR>> =
Since your=20
current project specifies "2.5", you won't be able to set<BR>> the =
target=20
runtime or deploy to Tomcat 5.5 since it only supports up<BR>> =
through=20
version "2.4". I would recommend creating a new project =
with<BR>> "2.4"=20
as the "Dynamic Web Module" facet, which choosing the Tomcat<BR>> 5.5 =
runtime=20
would accomplish. If you plan to deploy on either, make<BR>> =
sure the=20
Java facet is set for the lower of the versions your Tomcat<BR>> 5.5 =
and=20
Tomcat <BR>> 6.0 are running with, if there happens to be a =
difference. =20
Then copy<BR>> the content from the old project to the new one and =
port any=20
web.xml<BR>> changes necessary.<BR>> <BR>> Cheers,<BR>>=20
Larry</SPAN></DIV></BODY></HTML>
------=_NextPart_000_0019_01C86337.758216B0--
Re: How to change the target server after creating a Dynamic Web Project? [message #207778 is a reply to message #207759] |
Wed, 30 January 2008 08:31   |
This will fix the facet and target runtime of the project, but not its
content or related metadata. If you know the content didn't contain any
use of "2.5" features, then you are probably okay. I'm not aware of any
cached info under the ".metadata" folder of your workspace, but it's not
my area of expertise. At least make sure the content of your web.xml is
to "2.4" spec and not "2.5".
Larry
Michael Moser wrote:
> Hi Larry,
> <classpathentry exported="true" kind="con"
> path=" org.eclipse.jst.server.core.container/org.eclipse.jst.server .tomcat.runtimeTarget/Apache
> Tomcat v6.0"/>
> to:
> Tomcat v5.5"/>
> classpath.helper/org.eclipse.jst.server.core.container\:\:or g.eclipse.jst.server.tomcat.runtimeTarget\:\:Apache\
> Tomcat\ v6.0/owners=jst.web\:2.5
> to:
> Tomcat\ v5.5/owners=jst.web\:2.4
> And in .settings/org.eclipse.wst.common.project.facet.core.xml I changed:
> <runtime name="Apache Tomcat v6.0"/>
> <installed facet="jst.web" version="2.5"/>
> to:
> <runtime name="Apache Tomcat v5.5"/>
> <installed facet="jst.web" version="2.4"/>
> Michael
>> 5.5 and Tomcat
>> changes necessary.
>> Cheers,
>> Larry
Re: How to change the target server after creating a Dynamic Web Project? [message #207792 is a reply to message #207759] |
Wed, 30 January 2008 10:17   |
Don't forget to change the deployment descriptor(web.xml) header. There
is several places where the 2.5 is referecing to jee, but in the 2.4
cases it used to be j2ee. In addition the version number is also
referenced in the DD.
I second the comment from Larry. If you know the project doesn't use any
2.5 functionality you are probably okay with these changes.
"Michael Moser" <mmo@zurich.ibm.com> wrote in
news:fnpl93$5u2$1@build.eclipse.org:
> Hi Larry,
> things straight "manually". Just in case anybody has to do the same
> ever - here is what I had to do:
c
> at.runtimeTarget/Apache Tomcat v6.0"/> to:
c
\:org.eclipse.j
> st.server.tomcat.runtimeTarget\:\:Apache\ Tomcat\
> v6.0/owners=jst.web\:2.5 to:
\:org.eclipse.j
> v5.5/owners=jst.web\:2.4 And in
> <runtime name="Apache Tomcat v6.0"/> ...
> to:
> Michael
>> 5.5 and Tomcat
>> changes necessary.
>> Cheers,
>> Larry
> <HTML><HEAD><LINK href="C:\Program Files\OE-QuoteFix\styles.css"
> rel=stylesheet> <META http-equiv=Content-Type content="text/html;
> charset=iso-8859-1"> <META content="MSHTML 6.00.6000.16595"
> name=GENERATOR> <STYLE></STYLE>
> </HEAD>
> <BODY>
> <DIV><SPAN class=q0>Hi Larry,</SPAN></DIV>
> <DIV><SPAN class=q0>I considered your procedure a bit tedious and so I
> decided to set things straight "manually". </SPAN><SPAN class=q0>Just
> in case anybody has to do the same ever - h</SPAN><SPAN class=q0>ere
> is what I had to do:</SPAN></DIV>
> <DIV><SPAN class=q0></SPAN> </DIV>
> <DIV><SPAN class=q0>In .classpath I changed:</SPAN></DIV>
> <DIV><FONT color=#008080 size=2><</FONT><FONT color=#3f7f7f
> size=2>classpathentry </FONT><FONT color=#7f007f
> size=2>exported</FONT><FONT size=2>=</FONT><FONT color=#2a00ff
> size=2>"true" </FONT><FONT color=#7f007f size=2>kind</FONT><FONT
> size=2>=</FONT><FONT color=#2a00ff size=2>"con" </FONT><FONT
> color=#7f007f size=2>path</FONT><FONT size=2>=</FONT><FONT
> color=#2a00ff
> size=
> mcat.runtimeTarget/Apache Tomcat v6.0"</FONT><FONT color=#008080
> size=2>/></FONT></DIV> <DIV><FONT color=#008080 size=2>
> <DIV><SPAN class=q0>to:</SPAN></DIV></DIV></FONT></SPAN></DIV>
> color=#2a00ff
> size=
> mcat.runtimeTarget/Apache Tomcat v5.5"</FONT><FONT color=#008080
> size=2>/></DIV></FONT> <DIV><SPAN class=q0><SPAN
> class=q0> </DIV> <DIV>
> <DIV><SPAN
> class=q0>In
> core. I changed:<BR><FONT
> size=2>classpath.helper/org.eclipse.jst.server.core.container\: </FONT>
> FONT color=#2a00ff
> size=2>\:org.eclipse.jst.server.tomcat.runtimeTarget\:\:Apache\ </FONT>
> FONT size=2> </FONT><FONT color=#2a00ff size=2>Tomcat\</FONT><FONT
> size=2> </FONT><FONT color=#2a00ff size=2>v6.0/owners</FONT><FONT
> size=2>jst.web\:2.5<BR></FONT></SPAN></SPAN><SPAN class=q0><SPAN
> class=q0><FONT size=2>to:</FONT><BR><FONT
> size=2>classpath.helper/org.eclipse.jst.server.core.container\: <FONT
> color=#2a00ff>\:org.eclipse.jst.server.tomcat.runtimeTarget\:\:Apache
> /FONT> <FONT color=#2a00ff>Tomcat\</FONT> <FONT
> color=#2a00ff>v5.5/owners</FONT>=</FONT><FONT color=#2a00ff
> size=2>jst.web\:2.4</FONT></SPAN></SPAN></DIV>
> <P><SPAN class=q0><SPAN class=q0><SPAN class=q0>And
> I changed:<BR></SPAN></SPAN><SPAN class=q0><FONT size=2><FONT
> color=#008080 size=2><</FONT><FONT color=#3f7f7f size=2>runtime
> </FONT><FONT color=#7f007f size=2>name</FONT><FONT
> size=2>=</FONT><FONT color=#2a00ff size=2>"Apache Tomcat
> v6.0"</FONT><FONT color=#008080 size=2>/><BR></FONT><FONT
> color=#008080 size=2>...<BR></FONT><FONT color=#008080
> size=2><</FONT><FONT color=#3f7f7f size=2>installed </FONT><FONT
> color=#7f007f size=2>facet</FONT><FONT size=2>=</FONT><FONT
> color=#2a00ff size=2>"jst.web" </FONT><FONT color=#7f007f
> size=2>version</FONT><FONT size=2>=</FONT><FONT color=#2a00ff
> size=2>"2.5"</FONT><FONT color=#008080
> size=2>/><BR></FONT></FONT><FONT color=#008080 size=2><SPAN
> class=q0>to:<BR></SPAN><</FONT><FONT color=#3f7f7f size=2>runtime
> v5.5"</FONT><FONT color=#008080 size=2>/><BR></FONT><FONT
> size=2>"2.4"</FONT><FONT color=#008080
> size=2>/></P></DIV></FONT></SPAN> <DIV><SPAN class=q0>I am not sure
> whether ALL of these changes are really necessary, but I changed them
> all for consistency.</SPAN></DIV> <DIV><SPAN
> class=q0></SPAN> </DIV> <DIV><SPAN class=q0>After that the
> project turned out to "Tomcat 5.5 compliant"!</SPAN></DIV>
> <DIV><SPAN class=q0><FONT face=Arial size=2></FONT></SPAN> </DIV>
> <DIV><SPAN class=q0>Michael</SPAN></DIV>
> <DIV><SPAN class=q0></SPAN><SPAN class=q0></SPAN> </DIV>
> <DIV><SPAN class=q0>Larry Isaacs wrote:<BR></SPAN><SPAN class=q1>>
> modification.<BR>> Since your current project specifies "2.5", you
> won't be able to set<BR>> the target runtime or deploy to Tomcat
> 5.5 since it only supports up<BR>> through version "2.4". I
> would recommend creating a new project with<BR>> "2.4" as the
> make<BR>> sure the Java facet is set for the lower of the versions
> your Tomcat<BR>> 5.5 and Tomcat <BR>> 6.0 are running with, if
> there happens to be a difference. Then copy<BR>> the content
> from the old project to the new one and port any web.xml<BR>>
FUDForum. Page generated in 1.11270 seconds
