Home » Eclipse Projects » Eclipse Platform » IFile
IFile [message #20022] Mon, 28 April 2003 11:51 Go to next message
Originally posted by: pebraert.vub.ac.be
I want to set the contents of a file. The inputs I am using come from an
Eclipse editor, and are a String.
The Interface org.eclipse.core.resources.IFile only provides a method that
takes an InputStream as a paramer for setting the contents of a file.
Problem is that String InputStreams are deprecated. According to my java
API, we should use StringReader from now on.
So...
Is there a way to change a StringReader to a InputStream?
or...
Is there another way to change this problem?
Maybe expanding the IFile Interface with a method that takes a
StringReader as an input?
Peter
Re: IFile [message #20467 is a reply to message #20022] Mon, 28 April 2003 12:25 Go to previous messageGo to next message
I think what you want to do is break the string into a byte array. Then
create a ByteArrayInputStream. Use that to setContents(InputStream, int,
IProgressMonitor).
Peter Ebraert wrote:
> Hello,
> So...
> or...
> Peter
Re: IFile [message #20478 is a reply to message #20467] Mon, 28 April 2003 13:02 Go to previous message
Yeah, that did the job...
Peter
> IProgressMonitor).
> > Hello,
> > So...
> > or...
> > Thanks,
> > Peter
Previous Topic:shared launch configuration
Next Topic:Hiding external JARs in project view
Current Time: Fri Nov 14 08:21:39 EST 2025
Powered by FUDForum. Page generated in 0.03229 seconds
