Home » Modeling » GMF (Graphical Modeling Framework) » DnD in GMF Editor
DnD in GMF Editor [message #207529] |
Tue, 30 September 2008 09:52  |
Originally posted by: manojm.blr.interrasystems.com
Hi!
Could you suggest - how do I DnD an element from treeviewer (other than
ecore model) GMF editor?
Manoj
Re: DnD in GMF Editor [message #207810 is a reply to message #207758] |
Fri, 03 October 2008 10:42   |
Hi Manoj
At a high level, Drag and Drop in Eclipse requires DragSourceListener and
DropTargetListener, both in SWT.
Bring up the class hiearchy for these two interfaces to find the GMF classes
that implement them.
Look in the packages and plug-ins where these classes exist.
Done, you have found the DND implementation in the GMF Runtime.
Let us know if this does not help.
Cheers...
Anthony
"Manoj Mitra" <manojm@blr.interrasystems.com> wrote in message
news:48E5BAD5.3030704@blr.interrasystems.com...
> Hi! Anthony,
> Could you please tell - where this dnd handler is implemented?
> Manoj
> Anthony Hunter wrote:
>> Hi Manoj
>> Get the GMF logic editor example. When you run the example, the wizard
>> allows you to store the semantics in a separate semantic resource. Now
>> open both the EMF editor for the semantic logic resource file and the GMF
>> diagram editor. You can create a LED in the EMF editor and drag it to the
>> diagram editor. So you now have an example dragging from a tree viewer to
>> a GMF editor.
>> If you look at the source code, there is a dnd handler that handles the
>> drop as an EObject, but you can create any dnd transfer adapter you want.
>> Cheers...
>> Anthony
>> news:gbtav4$7o2$1@build.eclipse.org...
>>>Hi!
>>>Regards,
>>>Manoj
Re: DnD in GMF Editor [message #208516 is a reply to message #207810] |
Tue, 14 October 2008 07:54   |
Hi! Anthony,
I tried it by implementing TransferDropTargetListener.
While dragging the element from treeviewer, I can see it working(using
Systrace), but can not drop the element in editpart.
Could you please provide some link of code snippet?
Manoj
> Hi Manoj
> Cheers...
> Anthony
>>Hi! Anthony,
>>Regards,
>>Manoj
>>>Hi Manoj
>>>a GMF editor.
>>>Cheers...
>>>Anthony
>>>>Hi!
>>>>Regards,
>>>>Manoj
Re: DnD in GMF Editor [message #208864 is a reply to message #208516] |
Thu, 16 October 2008 09:13   |
Hi!
Have you found any example kind?
I have implemented AbstractDropTargetListener to my editor. Using whicth
I can see the handleDrop() responding.
Also I Habe implemented DragDropEditPolicy on editpart,
but while dropping on editpart it not listening.
On drop, I want to create a chile element on it.
Manoj
Manoj Mitra wrote:
> Hi! Anthony,
> Manoj
>> Hi Manoj
>> and DropTargetListener, both in SWT.
>> classes that implement them.
>> Cheers...
>> Anthony
>>> Hi! Anthony,
>>> Regards,
>>> Manoj
>>>> Hi Manoj
>>>> wizard allows you to store the semantics in a separate semantic
>>>> resource. Now open both the EMF editor for the semantic logic
>>>> resource file and the GMF diagram editor. You can create a LED in
>>>> the EMF editor and drag it to the diagram editor. So you now have an
>>>> example dragging from a tree viewer to a GMF editor.
>>>> the drop as an EObject, but you can create any dnd transfer adapter
>>>> you want.
>>>> Cheers...
>>>> Anthony
>>>>> Hi!
>>>>> than ecore model) GMF editor?
>>>>> Regards,
>>>>> Manoj
Re: DnD in GMF Editor [message #209124 is a reply to message #207659] |
Tue, 21 October 2008 20:33  |
> Hi Manoj
> allows you to store the semantics in a separate semantic resource. Now open
> both the EMF editor for the semantic logic resource file and the GMF diagram
> editor. You can create a LED in the EMF editor and drag it to the diagram
> editor. So you now have an example dragging from a tree viewer to a GMF
> editor.
> If you look at the source code, there is a dnd handler that handles the drop
> Cheers...
> Anthony
>> Hi!
>> Regards,
>> Manoj
i have tried it ,just ad i tried with the taipan example,when the original
model is deleted,the droped model does not exist too!that is the
problem!maybe it is easy to make it when the model to be dropped is a
simple one,but when it is very complex,how to make a full deep copy of
it(them)?
thanks for you answer in advance
Current Time: Sun Aug 31 17:33:04 EDT 2025
Powered by FUDForum. Page generated in 0.03849 seconds
