Home » Eclipse Projects » Eclipse Platform » Problem? Examples plugin not showing up in 3.0M7/win32
Problem? Examples plugin not showing up in 3.0M7/win32 [message #207488] Mon, 08 March 2004 11:51
Originally posted by: support.2xp.co.uk
Can't locate the examples by following the manual instructions in the Help
http://127.0.0.1:12293/help/topic/org.eclipse.platform.doc.i sv/samples/samples.html
Installed eclipse-SDK-3.0M7-win32, and later eclipse-examples-3.0M7-win32 to
C:\Program Files\eclipse as per documentation.
No report that an update was detected when IDE launched.
Help variously says that the examples should be available from
File->New->Other or File->New but there is no sign of them, there or
anywhere else.
Checking the installed features on Help->About shows only 6 features
installed.
Checking the features directory on the disk shows the 7th directory
org.eclipse.sdk.examples_3.0.0\
and in the plugins directory
org.eclipse.compare.examples.xml_3.0.0\
org.eclipse.compare.examples_3.0.0\
and other *.examples.* packages.
Am I missing something?
Previous Topic:Help system in 3.0
Next Topic:Eclipse freeze on ant build
Current Time: Thu Nov 06 13:57:58 EST 2025
Powered by FUDForum. Page generated in 0.02936 seconds
