Syncing Projects On 2 Computers [message #207444] |
Tue, 21 June 2005 06:24  |
Originally posted by: hello.hello.com
I'm working on an Eclipse project, and I sometimes use one computer to do
the work, sometimes a different computer. The two computers are both on
the same network. What is the easiest way for me to keep them in sync?
Right now, when one project is out of date, I'm just deleting it and
re-importing the newest version from the other computer. This is obviously
a hack method and I'd like to find a better way.
Thanks for any help,
John
Re: Syncing Projects On 2 Computers [message #207559 is a reply to message #207510] |
Wed, 22 June 2005 02:08  |
Originally posted by: eclipse.rizzoweb.com
John wrote:
> Thanks for the reply Paul.
>> The easiest way is to network share the workspace. Then you can
>> access it from whichever computer you use.
> Problem with this is that it's pretty slow over my wireless network for
> some reason.
It is not a supported or recommended setup for Eclipse - it wants the
workspace and Project contents to be on local storage. Eclipse performs
TONS of file IO during normal operation, and thus relies on a fast IO
pipe to operate smoothly.
I like the recommendation to use CVS, but another option is to archive
(zip, tar) the Project directory and copy it between the machines. Just
make sure to delete the old copy before un-archiving a newly moved copy.
HTH,
Eric
FUDForum. Page generated in 0.25180 seconds
