Home » Eclipse Projects » GEF » Is it possible to build stand alone application with GEF?
Is it possible to build stand alone application with GEF? [message #207298] Thu, 12 January 2006 07:13 Go to next message
Originally posted by: shawn666.liu.gmail.com
Is it possible to build stand alone application with GEF? Without RCP and
Eclipse.
Re: Is it possible to build stand alone application with GEF? [message #211846 is a reply to message #207298] Wed, 15 March 2006 21:38 Go to previous messageGo to next message
Originally posted by: kd3725.gmail.com
> Eclipse.
I don't see why this can't be done. As long as you include the gef
plugins as part of your dependencies, it should be ok.
Re: Is it possible to build stand alone application with GEF? [message #212081 is a reply to message #211846] Fri, 17 March 2006 13:41 Go to previous messageGo to next message
kd3725 wrote:
>> and Eclipse.
Actually now I have the same question. IFileEditorInput cannot be used
when making an RCP app because RCP will not import org.eclipse.ui.ide
jar. Is there a work around? I was told to implement IPathEditorInput,
but I have no idea what I would fill the methods with since I have not
seen an EditorInput implementation before.
TIA,
Diwant
Re: Is it possible to build stand alone application with GEF? [message #212173 is a reply to message #212081] Sun, 19 March 2006 20:50 Go to previous messageGo to next message
Originally posted by: nate.snapp.altiris.com
Good question,
I saw an answer posted a while back in a GEF/EMF article:
http://www.eclipse.org/articles/Article-GEF-EMF/gef-emf.html (under the
section "Bonus: Shapes Example goes RCP!")
Basically we can roll our own editor input with IPathEditorInput (which
implements the IEditorInput) and change the setInput() function in our
editor to accept the new editor input we have created.
Re: Is it possible to build stand alone application with GEF? [message #212270 is a reply to message #212173] Mon, 20 March 2006 11:42 Go to previous message
Nate Snapp wrote:
> Good question,
I think I read the same one! However, it doesn't hint to how to
implement the IPathEditorInput interface. Also, I changed my project
includes and now it seems to find IFileEditorInput. I really wish I
knew what I did exactly to make this work, though.
kd3
Previous Topic:Selection Problem when two GEF editor instances are running
Next Topic:Delete action remains disabled unless I have the editor add a second copy
Current Time: Sun Nov 09 04:39:58 EST 2025
Powered by FUDForum. Page generated in 0.04035 seconds
