Home » Archived » BIRT » org.eclipse.birt.report.model.elements.OdaDataSource.setIntrinsicProperty
org.eclipse.birt.report.model.elements.OdaDataSource.setIntrinsicProperty [message #207154] Mon, 18 December 2006 15:26 Go to next message
Originally posted by: dpatters.nassco.com
There was a thread on this, but no resolution posted. That thread was
specific to a WEB implementation, not a desktop implementation.
The specific report runs correctly from genReport.bat in the 2.1.1
runtime, and has a simple jdbc->odbc bridge connection.
However, when I try and run the same report in a stand-alone JAVA
application, I get the NPE error.
Original thread:
http://dev.eclipse.org/newslists/news.eclipse.birt/msg14403. html
Dennis
Re: org.eclipse.birt.report.model.elements.OdaDataSource.setIntrinsicProperty [message #209892 is a reply to message #207154] Mon, 08 January 2007 15:33 Go to previous message
Can you post the code you are using to run the report?
Jason
"Dennis " <dpatters@nassco.com> wrote in message
news:8927a0ae024d87ea044c631586173101$1@www.eclipse.org...
> Original thread:
> Dennis
Previous Topic:Report params use in dataset beforeOpen no longer works for 2.1.1
Next Topic:calling stored procedure in birt report??
Current Time: Fri Oct 31 02:09:34 EDT 2025
Powered by FUDForum. Page generated in 0.03957 seconds
