Home » Newcomers » Newcomers » noob; First time compiling, can anyone help?
noob; First time compiling, can anyone help? [message #207138] Tue, 24 April 2007 18:09 Go to next message
Originally posted by: muscles641.yahoo.com
I am trying to compile code provided by Intel UPNP. As I understand the
process, I should do the following:
Start Eclipse
File/New/Standard Make C++ Project
Import/File System/select directory
Properties/Make Build/ deselect all option
I should be able to build this now, but the only thing that gets built is
main.o
Can someone please set me through the process
Here is the contents of the folder.
ILibAsyncServerSocket.c
ILibAsyncServerSocket.h
ILibAsyncSocket.c
ILibAsyncSocket.h
ILibParsers.c
ILibParsers.h
ILibWebClient.c
ILibWebClient.h
Main.c
Main.h
Makefile
Makefile contains
# Intel's UPnP MicroStack/1.0, Sample MakeFile */
# Intel Device Builder - Build#1.0.1868.18043
# List all object files here
OFILES = \
Main.o \
ILibParsers.o\
ILibAsyncSocket.o\
ILibAsyncServerSocket.o\
ILibWebClient.o\
ILibWebServer.o\
UPnPMicroStack.o
# Compiler command name
CC = gcc
# Compiler flags applied to all files
CFLAGS = -Os -Wall -D_POSIX -D_DEBUG -D_VERBOSE
LIBS = -lpthread -lm
# Name of the executable
EXENAME = Main
# Builds all object files and executable
${EXENAME} : $(OFILES)
$(CC) $(CFLAGS) -o ${EXENAME} $(OFILES) $(LIBS)
# Macro rule for all object files.
$(OFILES) : \
UPnPMicroStack.h
# Clean up
clean :
rm -f $(OFILES) ${EXENAME} ${EXENAME}.exe
Re: noob; First time compiling, can anyone help? [message #207363 is a reply to message #207138] Wed, 25 April 2007 04:16 Go to previous message
> the process, I should do the following:
> Start Eclipse
> is main.o
You better ask this on the CDT newsgroup.
Dani
> ILibAsyncSocket.c
> ILibAsyncSocket.h
> ILibParsers.c
> ILibParsers.h
> ILibWebClient.c
> ILibWebClient.h
> Main.c
> Main.h
> Makefile
> Makefile contains
> OFILES = \
> Main.o \
> ILibParsers.o\
> ILibAsyncSocket.o\
> ILibWebClient.o\
> ILibWebServer.o\
> UPnPMicroStack.o
> CC = gcc
> EXENAME = Main
> $(OFILES) : \
> UPnPMicroStack.h
> # Clean up
> clean :
Previous Topic:Using Key Preferences in my RCP App
Next Topic:no source file named..
Current Time: Thu Jul 17 21:59:27 EDT 2025
Powered by FUDForum. Page generated in 0.13079 seconds
