Home » Modeling » TMF (Xtext) » Re: [xtext] Error in the generated PartitionScanner
| Re: [xtext] Error in the generated PartitionScanner [message #19952] |
Fri, 08 August 2008 12:47  |
--------------030806020307050809080108
Sven Efftinge wrote:
> Hi Lorenzo,
> it would be best if you could provide a patch and file it in bugzilla,
> so that the issue is fixed for everybody :-)
there seem to be problems with bugzilla, so for the moment I'm posting
the patch here
hope this helps
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Content-Type: text/x-diff;
name="scanner_with_escape_chars_for_strings.patch"
Content-Disposition: inline;
filename="scanner_with_escape_chars_for_strings.patch"
### Eclipse Workspace Patch 1.0
#P xtext.generator
Index: main/src/org/openarchitectureware/xtext/editor/Utilities.xpt
RCS file: /cvsroot/architecturware/oaw_v4/xtext/xtext.generator/main/s rc/org/openarchitectureware/xtext/editor/Utilities.xpt,v
retrieving revision 1.6.2.3.2.1
diff -u -r1.6.2.3.2.1 Utilities.xpt
--- main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 31 May 2008 12:57:18 -0000 1.6.2.3.2.1
+++ main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 8 Aug 2008 16:16:50 -0000
@@ -103,8 +103,8 @@
rules.add(new MultiLineRule("/*","*/", comment));
rules.add(new SingleLineRule("//", "", comment));
�ENDIF-�
- rules.add(new MultiLineRule("\"","\"", string));
- rules.add(new MultiLineRule("'","'", string));
+ rules.add(new MultiLineRule("\"","\"", string, '\\'));
+ rules.add(new MultiLineRule("'","'", string, '\\'));
return rules;
--------------030806020307050809080108--
| Re: [xtext] Error in the generated PartitionScanner [message #21435 is a reply to message #21418] |
Sat, 23 August 2008 13:10  |
Scott wrote:
> It seems to me that the problem is that the STRING definition is
> incorrect. See this thread for my explanation of why I think this:
> http://www.openarchitectureware.org/forum/viewtopic.php?show topic=9640
> Also, should I be posting on this newsgroup or that one?
As I also answered to that thread:
Actually, concerning the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243608, which
now should be fixed in the CVS, the strings with backslashed quotes used
to work correctly as before (the parser used to parse it correctly), it
was the highlighter that was wrong...
Current Time: Sun Nov 23 16:34:50 EST 2025
Powered by FUDForum. Page generated in 0.03602 seconds
