Home » Archived » BIRT » Error create data set with computed column
Error create data set with computed column [message #206967] Mon, 18 December 2006 05:57 Go to next message
I try to create simple query with computed column like folowing:
select o.InsertTime/1000 myValue
from orders o
And I got an error:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.1.1.v20060922-1058
Error Code:odaconsumer.CannotGetResultSetMetaData
Error Message:Cannot get the result set metadata.
SQL statement does not return a ResultSet object.
SQL error #1: General error, message from server: "Unknown table 'o' in
field list"
Its query successfully selects data in mysql console on the same database.
PS. Eclipse 3.2.1, BIRT 2.1.1.v20060926-0959
Re: Error create data set with computed column [message #207159 is a reply to message #206967] Mon, 18 December 2006 15:47 Go to previous message
Take a look at https://bugs.eclipse.org/bugs/show_bug.cgi?id=160724
Jason
"Sergey A. Lisovoy" <s.lisovoy@spb.solidworks.ru> wrote in message
news:em5s2l$lmj$1@utils.eclipse.org...
> from orders o
> And I got an error:
> field list"
Previous Topic:Hibernate on BIRT -Viewer Internal error problem
Next Topic:Report Properties
Current Time: Sun Nov 09 18:15:10 EST 2025
Powered by FUDForum. Page generated in 0.06095 seconds
