| Annoying problem with debugger, 3.1RC1, Java 1.5 [message #206785] |
Wed, 15 June 2005 18:38  |
Originally posted by: mgreenberg.dctd_dot_saic.com
I am debugging some code written with Java 1.5. Every time I click on a core
java object type (String, HashMap, HashSet...) in the Variables window, I get a
dailog the first time (for each type) that says, e.g.:
Select Source File
HashMap.class
java/util/HashMap.java - c:\Program Files\Java\jdk1.5.0_02\src.zip
This happens the first time I click on an object of that type (HashMap in this
example). But the problem recurs if I restart debugging.
Obviously something in my path,buildpath, etc. is confusing the JDT, but I don't
really understand why the debugger wants a SOURCE file to (as I understand it)
run the toString() method on the object.
My rt.jar is at c:\Program Files\Java\jdk1.5.0_03\jre\lib, with attached source
C:\Program Files\Java\jdk1.5.0_03\src.zip
| Re: Annoying problem with debugger, 3.1RC1, Java 1.5 [message #206854 is a reply to message #206785] |
Thu, 16 June 2005 10:48   |
Sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=100357
Kevin
> core java object type (String, HashMap, HashSet...) in the Variables
> window, I get a dailog the first time (for each type) that says, e.g.:
> Select Source File
> HashMap.class
> in this example). But the problem recurs if I restart debugging.
> I don't really understand why the debugger wants a SOURCE file to (as I
> understand it) run the toString() method on the object.
> source
FUDForum. Page generated in 0.07496 seconds
