Re: creating a jet project [message #19993 is a reply to message #19896] |
Tue, 05 June 2007 08:38   |
------=_NextPart_000_000A_01C7A74C.EF670E10
Content-Type: text/plain;
charset="iso-8859-1"
Alexandre:
You need to install JET separately. You can download from the M2T (Model =
to Text) site, you you can use the following update site:
http://download.eclipse.org/modeling/m2t/updates/site.xml
If you want pre-release builds of the upcoming JET release (Jun 30, =
2007), you can use this update site:
http://download.eclipse.org/modeling/m2t/updates/site-interi m.xml
Paul
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:f43hd0$9f6$2@build.eclipse.org...
Alexandre,
Did you install JET2? =20
http://www.eclipse.org/modeling/m2t/
You should ask about JET2 on the M2T newsgroup, which I've added to =
the "to" on my reply.
Alexandre Jaquet wrote:=20
I'm trying to follow this tutorial
http://www-128..ibm.com/developerworks/java/library/os-ecl-j et/index.html=
?ca=3Ddrs
but I doesn't found the wizard File > New > Other > EMFT JET =
Transformations=20
> EMFT JET Transformation Project
I'm been runing emf 2.2.3 sdk.
Any idea ?
Alexandre=20
=20
Content-Type: text/html;
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3086" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Alexandre:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>You need to install JET separately. You =
can=20
download from the M2T (Model to Text) site, you you can use the =
following update=20
site:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><A=20
href=3D"http://download.eclipse.org/modeling/m2t/updates/site.xml">http:/=
/download.eclipse.org/modeling/m2t/updates/site.xml</A></FONT ></DIV>
<DIV><FONT face=3DArial size=3D2>If you want pre-release builds of the =
upcoming JET=20
release (Jun 30, 2007), you can use this update site:</FONT></DIV>
href=3D" http://download.eclipse.org/modeling/m2t/updates/site-interi m.xml=
"> http://download.eclipse.org/modeling/m2t/updates/site-interi m.xml</A></=
FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:f43hd0$9f6$2@build.eclipse.org">news:f43hd0$9f6$2@build.ecli=
pse.org</A>...</DIV>Alexandre,<BR><BR>Did=20
you install JET2? <BR>
<BLOCKQUOTE><A=20
href=3D"http://www.eclipse.org/modeling/m2t/">http://www.eclipse.org/mode=
ling/m2t/</A><BR></BLOCKQUOTE>You=20
should ask about JET2 on the M2T newsgroup, which I've added to the =
"to" on my=20
reply.<BR><BR><BR>Alexandre Jaquet wrote:=20
<BLOCKQUOTE cite=3Dmid:f43dec$1f0$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">I'm trying to follow this tutorial
<A class=3Dmoz-txt-link-freetext =
href=3D" http://www-128.ibm.com/developerworks/java/library/os-ecl-je t/ind=
ex.html?ca=3Ddrs">http://www-128..ibm.com/developerworks/java/library/os-=
ecl-jet/index.html?ca=3Ddrs</A>
Transformations=20
Any idea ?
Alexandre=20
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000A_01C7A74C.EF670E10--
Re: creating a jet project [message #20721 is a reply to message #19993] |
Wed, 06 June 2007 03:11  |
------=_NextPart_000_002E_01C7A81A.BAB022F0
Thanks it's work fine now.
Alexandre
"Paul Elder" <pelder@ca.ibm.com> a =E9crit dans le message de news: =
f43lho$o78$1@build.eclipse.org...
Alexandre:
You need to install JET separately. You can download from the M2T =
(Model to Text) site, you you can use the following update site:
Paul
Alexandre,
?ca=3Ddrs
Transformations=20
Any idea ?
Alexandre=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.5730.11" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Thanks it's work fine now.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Alexandre</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Paul Elder" <<A=20
href=3D"mailto:pelder@ca.ibm.com">pelder@ca.ibm.com</A>> a =E9crit =
dans le=20
message de news: <A=20
href=3D"mailto:f43lho$o78$1@build.eclipse.org">f43lho$o78$1@build.eclipse=
..org</A>...</DIV>
<DIV><FONT face=3DArial size=3D2>You need to install JET separately. =
You can=20
following=20
upcoming=20
JET release (Jun 30, 2007), you can use this update site:</FONT></DIV>
FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>> wrote in =
message <A=20
<BLOCKQUOTE><A=20
"to" on=20
my reply.<BR><BR><BR>Alexandre Jaquet wrote:=20
Transformations=20
Any idea ?
Alexandre=20
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_000_002E_01C7A81A.BAB022F0--
FUDForum. Page generated in 0.06973 seconds
