Home » Archived » DSDP - Real-Time Software Components (RTSC) » How to handle error in Module_startup()?
How to handle error in Module_startup()? [message #1659] Thu, 12 March 2009 14:55 Go to next message
Champs,
What is the recommended way to handle and error in <<Mod>>_Module_startup()? Should I raise an error? Should I create a local error block and pass this to other modules? Should I always return NOTDONE when an error occurs?
~ Ramsey
Re: How to handle error in Module_startup()? [message #1705 is a reply to message #1659] Mon, 16 March 2009 11:29 Go to previous message
Ramsey Harris wrote:
> Champs,
> Thanks
> ~ Ramsey
Since startup occurs _very_ early, before main(), it is best to _never_
fail in startup. It's very difficult for a user to determine what the
problme is when their application never makes it to main().
You can set a flag in your startup to indicate the failure and then fail
"normally" in your modules API's due to a startup problem.
If, on the other hand, it is important that the application not proceed
if the startup fails, you can call System_abort().
Previous Topic:Problems with RTSC packages and legacy binary objects
Next Topic:Is there handle up-casting in meta-domain?
Current Time: Wed Nov 19 15:27:31 EST 2025
Powered by FUDForum. Page generated in 0.04851 seconds
