Home » Archived » BIRT » Report parameters with multiplicity n
Report parameters with multiplicity n [message #206377] Thu, 14 December 2006 14:57 Go to next message
Hopefully this is easy to do, but I've looked at the API, the report
designer, and documentation and found no mention of it.
Say my report has a parameter named "a", of type String. I can
dynamically compute the valid values to choose from, this all works
fine. What I now want to do is to allow n of these values to be passed
in to the report, in a list, array, collection, or something of the
sort. Is this possible?
Assuming it is possible, how does having "a" in a cascading parameter
group affect the functionality?
Assuming it is possible, are there any tricks I need to know about in
order to pass the value(s) through to my scripted ODA data source?
I'm using BIRT 2.1.1.
james
Re: Report parameters with multiplicity n [message #206762 is a reply to message #206377] Fri, 15 December 2006 12:42 Go to previous messageGo to next message
BIRT currently does not support paramaters with a collection type.
A report can get access to the request parameters though. You may be able
to do it that way.
Jason
"James Moody" <James_Moody@ca.ibm.com> wrote in message
news:elsaar$5fk$1@utils.eclipse.org...
> Say my report has a parameter named "a", of type String. I can dynamically
> compute the valid values to choose from, this all works fine. What I now
> want to do is to allow n of these values to be passed in to the report, in
> a list, array, collection, or something of the sort. Is this possible?
> james
Re: Report parameters with multiplicity n [message #206802 is a reply to message #206762] Fri, 15 December 2006 16:38 Go to previous messageGo to next message
Hi Jason,
Does it mean that you can only pass one parameter at a time to the report,
I am sorry but I dont understand what you said about passing multiple
parameters to a report.
If I am not worng wrong what you mean to say is that though you can pass
in multiple parameters for a report you cant pass multiple values of a
single parameter like in the form of an Array,List or things of that
nature.
Please clarify.
Thanks!
Re: Report parameters with multiplicity n [message #206862 is a reply to message #206802] Fri, 15 December 2006 23:15 Go to previous messageGo to next message
Sorry I was not clear. You can pass multiple parameters, just not multiple
values for the
same parameter.
Jason
"Birt Guy" <merkhan@tiaa-cref.org> wrote in message
news:d3d3bed5a8079260d2e8ae018b1fb9c8$1@www.eclipse.org...
> Hi Jason,
> nature.
> Please clarify.
> Thanks!
Re: Report parameters with multiplicity n [message #207077 is a reply to message #206862] Mon, 18 December 2006 10:47 Go to previous messageGo to next message
Thanks for the reply Jason!
Is there any work around for this limitation of BIRT , If so can you
please shed some light on the possible workaround.
Thanks!
Re: Report parameters with multiplicity n [message #207250 is a reply to message #207077] Tue, 19 December 2006 09:38 Go to previous message
You could store objects in session and then use JavaScript to get the stored
values
in the beforeFactory event.
Jason
news:130e19b32e6ed29dbde2cc05c584ccab$1@www.eclipse.org...
> Thanks!
Previous Topic:comment not terminated properly error bugging me while creating reports
Next Topic:problen in birt-runtime-2_1_1 WAS 6.01
Current Time: Sun Aug 31 14:23:40 EDT 2025
Powered by FUDForum. Page generated in 0.04096 seconds
