Home » Modeling » GMF (Graphical Modeling Framework) » self-containing compartment?
self-containing compartment? [message #206314] Mon, 22 September 2008 16:06 Go to next message
how can I make a self-containing compartment? - a compartment that has as
compartments itself (from the same type).
for example Element A is a compartment and the user would be able to
create the following compartments (and continue to do it recursively):
==A=================
= =A==== =A==== =
Should I change also the ecore model? Element A to have as an attribute
many children of itself?
Thank You,
Nikolay
Re: self-containing compartment? [message #206445 is a reply to message #206314] Tue, 23 September 2008 04:55 Go to previous messageGo to next message
Hello Nikolay,
> attribute many children of itself?
Yes. In addition see http://wiki.eclipse.org/GMF_MapModel_Hints#Endless.2Frecursi ve_hierarchies
+ GMF tutorials describing inner nodes.
Alex Shatalin
Re: self-containing compartment? [message #207143 is a reply to message #206445] Fri, 26 September 2008 06:34 Go to previous message
Thanks Alex, it worked out! :)
Nikolay
Previous Topic:Re: DND from TreeViewer to GMF generated editor
Next Topic:fail in saving diagram file
Current Time: Wed Nov 26 07:40:14 EST 2025
Powered by FUDForum. Page generated in 0.04030 seconds
