Home » Eclipse Projects » GEF » Change cursor for DND
Change cursor for DND [message #206019] Fri, 23 December 2005 15:10 Go to next message
I am using a TransferDropTargetListener to handle FileTransfer and
LocalSelectionTransfer. Some of the items that can be dragged over I want to
accept into the diagram, others I don't. Currently I have a check in
Command.canExecute() which returns false if and item is not acceptable. This
means that cursor shows that everything is okay, but when you release the
mouse button, nothing happens.
I would rather change mouse cursor to SWT.CURSOR_NO to give the user
immediate feedback. I tried overriding the showTargetFeedback() method on my
EditPolicy to change the cursor, but that lasted only for 1/10 of a second,
then old cursor was back.
Is there a way to show feedback with the cursor?
Re: Change cursor for DND [message #206218 is a reply to message #206019] Mon, 26 December 2005 23:52 Go to previous messageGo to next message
If there is no target editpart, the droptarget should not indicate that it
is enabled, which results in NOT sign if all are disabled. So, one answer is
to avoid being targeted when you don't accept a certain transfer type.
Why isn't canExecute used by default? Because the data being dropped is not
available until the drop is completed. If you want to use canExecute(), call
setEnabledDeterminedByCommand(true).
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dohlj9$9jn$1@utils.eclipse.org...
>to accept into the diagram, others I don't. Currently I have a check in
>This means that cursor shows that everything is okay, but when you release
>the mouse button, nothing happens.
> my EditPolicy to change the cursor, but that lasted only for 1/10 of a
> second, then old cursor was back.
Re: Change cursor for DND [message #206300 is a reply to message #206218] Wed, 28 December 2005 11:04 Go to previous messageGo to next message
Thanks a lot, unfortunately it looks like there is no solution. As you say,
the data being dropped is not available until the drop is completed, so
canExecute() does not work. I am not sure I understand the first part of
your answer, but my issue is that I want to accept some things that come
with a LocalSelectionTransfer and some I don't. So I have to install a
listener for the LocalSelectionTransfer, but I need a look at the actual
data before the drop is completed.
For the benefit of others reading this thread: The correct method call is
setEnablementDeterminedByCommand( true ).
"Randy Hudson" <none@us.ibm.com> wrote in message
news:doqh6d$aa0$1@utils.eclipse.org...
> is to avoid being targeted when you don't accept a certain transfer type.
> not available until the drop is completed. If you want to use
> canExecute(), call setEnabledDeterminedByCommand(true).
Re: Change cursor for DND [message #206335 is a reply to message #206300] Wed, 28 December 2005 15:49 Go to previous messageGo to next message
When dragging from the palette to the GV, I'm sure that we cheat and just
take the data from the transfer and make it available on the request, even
before drop occurs. But, this is only useful for targeting since we still
don't check the command's enablement (unless the client turns it on).
news:doucu5$mfl$1@utils.eclipse.org...
> say, the data being dropped is not available until the drop is completed,
> so canExecute() does not work. I am not sure I understand the first part
> of your answer, but my issue is that I want to accept some things that
> come with a LocalSelectionTransfer and some I don't. So I have to install
> a listener for the LocalSelectionTransfer, but I need a look at the actual
>> it is enabled, which results in NOT sign if all are disabled. So, one
>> answer is to avoid being targeted when you don't accept a certain
>> transfer type.
>>>release the mouse button, nothing happens.
>>> on my EditPolicy to change the cursor, but that lasted only for 1/10 of
>>> a second, then old cursor was back.
Re: Change cursor for DND [message #206383 is a reply to message #206335] Thu, 29 December 2005 13:01 Go to previous message
I got it to work for LocalSelectionTransfer with
setEnablementDeterminedByCommand(true)because it has the data in it right
away, event when the DropTargetEvent does not.
news:doutl4$gbp$1@utils.eclipse.org...
>> actual data before the drop is completed.
>>> transfer type.
>>>>want to accept into the diagram, others I don't. Currently I have a
>>>>check in Command.canExecute() which returns false if and item is not
>>>>acceptable. This means that cursor shows that everything is okay, but
>>>>when you release the mouse button, nothing happens.
Previous Topic:How to add undo/redo of my actions to GEF CommandStack?
Next Topic:XMIResource
Current Time: Sun Aug 31 08:04:18 EDT 2025
Powered by FUDForum. Page generated in 0.05116 seconds
