Home » Archived » Maven Integration (M2E) » [tycho] cannot run demo on 0.3.0-DEV-1819
| [tycho] cannot run demo on 0.3.0-DEV-1819 [message #19845] |
Fri, 12 December 2008 18:19  |
When I run "mvn org.codehaus.tycho:maven-tycho-plugin:generate-poms" on
1819, I get this error:
[ERROR]
Cannot find mojo descriptor for:
'org.codehaus.tycho:maven-tycho-plugin:generate
-poms' - Treating as non-aggregator.
The same command works on 0.3.0-DEV-1719. Any tips?
| Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #19942 is a reply to message #19918] |
Tue, 16 December 2008 19:49   |
Thanks for investigating. I tried again (in the same shell, in fact!)
and it worked fine. So this must have been an issue with my
connectivity or a temporary blip in the repo.
This was on Windows Vista, by the way (full command and output from
before is below).
After generating the poms, I was able to successfully build a
feature-based version of the tycho demo (something I couldn't do in
1719). It is truly quite amazing to see this happening in maven and I am
really looking forward to maven 3.0. I am willing to document the
feature-based steps if that would be helpful to others.
-Will
c:\workspaces\tycho-demo>c:\tycho-distribution-0.3.0-DEV-1819\bin\mvn
org.codehaus.tycho:maven-tycho-plugin:generate-poms -DgroupId=tycho.demo
-Dtycho.targetPlatform=c:\eclipse\eclipse-3.4.1-rcp
[INFO] Build target platform
tycho.targetPlatform=c:\eclipse\eclipse-3.4.1-rcp. This overrides target
platform specified in pom.xml files, if any.
[ERROR]
'org.codehaus.tycho:maven-tycho-plugin:generate-poms' - Treating as
non-aggregator.
[INFO]
[INFO] For more information, run with the -e flag
[INFO]
[INFO] BUILD FAILED
[INFO]
[INFO] Total time: < 1 second
[INFO] Finished at: Fri Dec 12 15:16:38 PST 2008
[INFO] Final Memory: 3M/7M
[INFO]
Igor Fedorenko wrote:
> Will,
> I just tried tycho demo script [1] on linux using 0.3.0-DEV-1819 and
> everything worked as expected. What platform you are on? What is exact
> command you used to generate pom.xml files? Can you rerun the command
> with error stack traces enabled (-e parameter) and post output here?
> As a side note, tycho needs really basic pom.xml files, so it should not
> be too difficult to write them by hand. And even for generated pom.xml
> files, I recommend keeping them as part of project source tree. This way
> you will be able to customize your build when needed.
> [1] http://docs.codehaus.org/display/M2ECLIPSE/Tycho+technology+ demo+script
> Igor
>> on 1819, I get this error:
>> [ERROR]
| Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #25197 is a reply to message #19942] |
Thu, 30 April 2009 07:57   |
Hi Will and Igor,
I am facing similar problem in Linux. I tried to clean ~/.m2/repository
to verify that my proxy allows to upload necessary plug-ins. To me it
seems that I cannot upload only maven-tycho-plugin.
Could you help?
-Petr
here is my command/output:
mvn -e org.codehaus.tycho:maven-tycho-plugin:generate-poms
-DgroupId=tycho.demo -Dtycho.targetPlatform=/home/petr/ganymede/eclipse/
+ Error stacktraces are turned on.
[INFO] Attempting to resolve a version for plugin:
org.codehaus.tycho:maven-tycho-plugin using meta-version: LATEST
[INFO] Using version: LATEST of plugin:
[ERROR]
non-aggregator.
Error stacktrace:
org.apache.maven.InvalidTaskException: Cannot find mojo descriptor for:
non-aggregator.
org.apache.maven.lifecycle.TaskValidationResult.generateInva lidTaskException(TaskValidationResult.java:78)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:182)
at org.apache.maven.embedder.MavenEmbedder.execute(MavenEmbedde r.java:846)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:160)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:63)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
org.codehaus.plexus.classworlds.launcher.Launcher.launchEnha nced(Launcher.java:289)
org.codehaus.plexus.classworlds.launcher.Launcher.launch(Lau ncher.java:229)
org.codehaus.plexus.classworlds.launcher.Launcher.mainWithEx itCode(Launcher.java:408)
org.codehaus.plexus.classworlds.launcher.Launcher.main(Launc her.java:351)
Caused by: org.apache.maven.plugin.loader.PluginLoaderException: Failed
to load plugin. Reason: Plugin could not be found - check that the goal
name is correct: Unable to determine the latest version
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.codehaus.tycho
-DartifactId=maven-tycho-plugin -Dversion=LATEST
-Dpackaging=maven-plugin -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file
there:
mvn deploy:deploy-file -DgroupId=org.codehaus.tycho
-Dpackaging=maven-plugin -Dfile=/path/to/file -Durl=[url]
-DrepositoryId=[id]
org.codehaus.tycho:maven-tycho-plugin:maven-plugin:LATEST
org.apache.maven.plugin.loader.DefaultPluginLoader.loadPlugi n(DefaultPluginLoader.java:99)
org.apache.maven.plugin.loader.DefaultPluginLoader.loadPlugi n(DefaultPluginLoader.java:54)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.getMojoD escriptorForDirectInvocation(DefaultLifecycleExecutor.java:8 50)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.isTaskVa lid(DefaultLifecycleExecutor.java:672)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:178)
... 11 more
Caused by: org.apache.maven.plugin.PluginNotFoundException: Plugin could
not be found - check that the goal name is correct: Unable to determine
the latest version
there:
-DrepositoryId=[id]
org.apache.maven.plugin.DefaultPluginManager.verifyVersioned Plugin(DefaultPluginManager.java:250)
org.apache.maven.plugin.DefaultPluginManager.verifyPlugin(De faultPluginManager.java:199)
org.apache.maven.plugin.loader.DefaultPluginLoader.loadPlugi n(DefaultPluginLoader.java:81)
... 15 more
[INFO]
[INFO] BUILD FAILED
[INFO]
> before is below).
> -Will
> [ERROR]
> non-aggregator.
> [INFO]
> [INFO]
> [INFO] BUILD FAILED
> [INFO]
> [INFO]
>> Will,
>> not be too difficult to write them by hand. And even for generated
>> pom.xml files, I recommend keeping them as part of project source
>> tree. This way you will be able to customize your build when needed.
>> [1]
>> Regards,
>> Igor
>>> [ERROR]
| Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #25238 is a reply to message #25197] |
Thu, 30 April 2009 10:06   |
Originally posted by: igor.ifedorenko.com
Petr,
Can you confirm that you are using Tycho installation to run
generate-poms? Also, check M2_HOME environment variable. If set, it must
point to Tycho installation.
Also, we have a mailing list dedicated to Tycho. You can subscribe by
sending email to tycho-users-subscribe@lists.sonatype.com.
Igor
Petr Baranov wrote:
> Hi Will and Igor,
> Could you help?
> -Petr
> [ERROR]
> non-aggregator.
> Error stacktrace:
> non-aggregator.
> at
> at
> at
> at
> at
> at
> at
> at
> there:
> -DrepositoryId=[id]
> at
> at
> at
> at
> ... 11 more
> the latest version
> there:
> -DrepositoryId=[id]
> at
> at
> at
> ... 15 more
> [INFO]
> [INFO] BUILD FAILED
> [INFO]
>> before is below).
>> am really looking forward to maven 3.0. I am willing to document the
>> -Will
>> -DgroupId=tycho.demo -Dtycho.targetPlatform=c:\eclipse\eclipse-3.4.1-rcp
>> target platform specified in pom.xml files, if any.
>> [ERROR]
>> non-aggregator.
>> [INFO]
>> [INFO]
>> [INFO] BUILD FAILED
>> [INFO]
>> [INFO]
>>> Will,
>>> exact command you used to generate pom.xml files? Can you rerun the
>>> command with error stack traces enabled (-e parameter) and post
>>> output here?
>>> [1]
>>> Regards,
>>> Igor
>>>> [ERROR]
| Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #25482 is a reply to message #25319] |
Thu, 07 May 2009 19:44  |
This probably does not help much, but I believe there were issues with
mirror and proxy support in Maven 3.0-alpha-1 used in Tycho.
FYI, Maven codebase is changing very quickly right now, so we decided to
wait until things settle down a bit before updating Tycho.
Igor
Joerg Buchberger wrote:
> Hi all,
> trying to use 0.3.0-DEV-1819 back in February and now 0.4.0-DEV-2233
> respectively, I had the very same problem. I still do not know the
> reason why, but I suppose it has to do with our company firewall.
> Once I installed Nexus (v1.3.3-gpl) and configured the tycho settings as
> described in the nexus docs... BUILD SUCCESSFUL.
> Note, that I have a 2.0.9 installation on the same machine, which never
> had any problems getting dependencies from public repos.
> Regards.
> Joerg
Current Time: Sun Nov 09 18:15:17 EST 2025
Powered by FUDForum. Page generated in 0.03942 seconds
