| Marker bar not present when running the debugger [message #205849] |
Thu, 04 March 2004 06:21  |
Originally posted by: david.duff.hanon.co.uk
I wonder if anyone can help me out.
When I set a breakpoint on a class and then run my web application. The
debugger stops at the line but no marker bar is present. The rest of the
behaviour is what I would expect but I've lost the bar when I step through
the class.
I thought it may be a configuration issue in eclipse. I'm using sysdeo
plugin for eclipse and was wondering if this plugin has any issues but for
what I can gather from the website. It doesn't seem to have.
Has anyone else had this problem?
Thank in advance.
David
| Re: Marker bar not present when running the debugger [message #259140 is a reply to message #206530] |
Wed, 07 July 2004 09:05  |
This issue has raised its head again. I am running the stable build of
Eclipse 3.0.
Again, when I set the breakpoint, when the breakpoint is hit, the line is
not highlighted. Short of deleting the workspace folder is there anything
else I can do to rectify this problem.
Thanks for your help.
Davie
"David Duff" <david.duff@hanon.co.uk> wrote in message
news:c2a19t$m9l$1@eclipse.org...
> Yeah, I think that is it.
> David
> "Darin Wright" <Darin_Wright@ca.ibm.com> wrote in message
> news:c27sgt$b33$1@eclipse.org...
> > There was a recent bug introduced that may cause this behavior. See:
> > https://bugs.eclipse.org/bugs/show_bug.cgi?id=53646
> > If this is not your problem, please enter a bug with steps to reproduce.
> > Darin
> > news:c27381$70t$1@eclipse.org...
> > > Hi,
The
> the
> through
> > > the class.
sysdeo
> for
> > > Thank in advance.
> > > David
FUDForum. Page generated in 0.04398 seconds
