Home » Eclipse Projects » GEF » geting started with graphical editor skeleton
geting started with graphical editor skeleton [message #205830] Thu, 22 December 2005 10:34 Go to next message
Hello everybody,
I would like to build graphical editor skeleton and relate it with my
existing EMF model. In manual it is written, that I should create a new
plug-in and define the editor extension. Should this new plug-in be the new
plug-in project? or I have to create it somehow in my EMF model project?
I tried to create it as separate plug-in project and add editor extension,
but what I find is only org.eclipse.ui.editors extension points where Editor
described in it is XML editor..:/
As I understand, when I finish plug-in creating wizard, I should have
default editor class generated which should extend EditorPart. How can I do
this?
Thank you in advance ;)
Re: geting started with graphical editor skeleton [message #205839 is a reply to message #205830] Thu, 22 December 2005 11:10 Go to previous messageGo to next message
I think you should stay away from the wizards. They don't create abstract
editors for you, just tect editors.
"Tomas" <tstankevicius@gmail.com> wrote in message
news:doeh2r$ksm$1@utils.eclipse.org...
> Hello everybody,
> new
> Editor
> do
> this?
Re: geting started with graphical editor skeleton [message #205873 is a reply to message #205839] Thu, 22 December 2005 12:40 Go to previous message
so the good thing would be just create simple empty plug-in project and and
start writing code? but do I still need to add something as a plug-in
extension?
"Randy Hudson" <none@us.ibm.com> wrote in message
news:doej6a$o5d$1@utils.eclipse.org...
> > Hello everybody,
> > new
extension,
> > Editor
> > do
> > this?
Previous Topic:How can create a connection between a node and a Connection
Next Topic:Problems creating gefgenmodel
Current Time: Fri Nov 14 18:15:28 EST 2025
Powered by FUDForum. Page generated in 0.23223 seconds
