Home » Eclipse Projects » Technology Project and PMC » org.eclipse.core.runtime 0 java.lang.NullPointerExceptio
org.eclipse.core.runtime 0 java.lang.NullPointerExceptio [message #19801] Fri, 30 August 2002 08:26
Originally posted by: dave_gagnon.tjx.com
Whenever I try to run a jsp on the server, I get an error message that
says "Internal error has occurred. Null argument. See log for
details." In the log it says that I got a null pointer exception on
ORG.ECLIPSE files. Below is the message from the log. I am using IBM
Websphere Studio Application Developer for Windows version 4.03/build
020301 and Websphere Studio Workbench version R1.0/build 0.137. If
anyone can offer any insight or suggestions, I would greatly
appreciate it. Thank you.
4 org.eclipse.core.runtime 0 java.lang.NullPointerException
org.eclipse.debug.internal.core.LaunchManager.findLaunch(Lau nchManager.java:86)
org.eclipse.debug.internal.core.RuntimeProcess.getLaunch(Run timeProcess.java:148)
org.eclipse.debug.internal.ui.DebugContentProvider.getParent (DebugContentProvider.java:154)
org.eclipse.debug.internal.ui.ProcessesContentProvider.doHan dleDebugEvent(ProcessesContentProvider.java:33)
org.eclipse.debug.internal.ui.BasicContentProvider$1.run(Bas icContentProvider.java:59)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:2 6)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java(Compiled
Code))
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a(Compiled
Code))
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
at org.eclipse.jface.window.Window.runEventLoop(Window.java:536 )
at org.eclipse.jface.window.Window.open(Window.java:523)
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:318)
org.eclipse.jface.window.Window.handleExceptionInEventLoop(W indow.java:436)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:539 )
org.eclipse.ui.internal.Workbench.handleExceptionInEventLoop (Workbench.java:362)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compiled
Code))
at org.eclipse.ui.internal.Workbench.run(Workbench.java:656)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:815)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:285)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:151)
at org.eclipse.core.launcher.Main.run(Main.java:442)
at org.eclipse.core.launcher.Main.main(Main.java:315)
Previous Topic:Compilation Help.. Please..
Next Topic:org.eclipse.core.runtime 0 java.lang.NullPointerExceptio
Current Time: Sat Jul 12 08:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.03247 seconds
