| Running JUnit Plugin Tests from outside eclipse? [message #205442] |
Tue, 17 April 2007 08:24  |
Hi All,
I have some plugins that have associated JUnit tests. I can kick off these
tests via the Run.. Junit Plugin Tests command. AS I understand it, this
kicks off a new JVM and Workbench, etc and then runs the tests on that.
Is it possible to kick off Junit Plugin tests from outside an eclipse
workbench? I'd like to include these plugin unit tests in our test bucket,
but this obviously requires some automation of the test invocations
Many Thanks
Andy
| Re: Running JUnit Plugin Tests from outside eclipse? [message #205450 is a reply to message #205442] |
Tue, 17 April 2007 08:29   |
--------------010509080706000103060108
Andrew,
If you look at the debug view for the JUnit process you've just run, you
can right click to see the properties and that shows how to invoke this
same thing from the command line. E.g.,
D:\sandbox\3.3M6\eclipse\jre\bin\javaw.exe -classpath
D:\sandbox\3.3M6\eclipse\plugins\org.eclipse.equinox.launche r_1.0.0.v20070319.jar
org.eclipse.equinox.launcher.Main -version 3 -port 3303
-testLoaderClass
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r
-loaderpluginname org.eclipse.jdt.junit.runtime -classNames
com.example.library.tests.LibraryAllTests -application
org.eclipse.pde.junit.runtime.coretestapplication -data
D:\sandbox\3.3M6\eclipse\eclipse\plugins/../junit-workspace
-configuration
file:D:/sandbox/3.3M6/eclipse/eclipse/plugins/.metadata/.plu gins/org.eclipse.pde.core/pde-junit/
-dev
file:D:/sandbox/3.3M6/eclipse/eclipse/plugins/.metadata/.plu gins/org.eclipse.pde.core/pde-junit/dev.properties
-pdelaunch -os win32 -ws win32 -arch x86 -testpluginname library.tests
Andrew Borley wrote:
> Hi All,
> these tests via the Run.. Junit Plugin Tests command. AS I understand
> it, this kicks off a new JVM and Workbench, etc and then runs the
> tests on that.
> bucket, but this obviously requires some automation of the test
> invocations
> Many Thanks
> Andy
<html>
<head>
http-equiv="Content-Type">
</head>
Andrew,<br>
<br>
you can right click to see the properties and that shows how to invoke
this same thing from the command line.
| Re: Running JUnit Plugin Tests from outside eclipse? [message #205650 is a reply to message #205450] |
Wed, 18 April 2007 05:56  |
Hi Ed,
Thanks for this info - I can now run something from the command line that
brings up my test workbench. Unfortunately, it doesn't seem to do anything
else - the workbench appears, doesn't do anything and then is
automatically killed after a period of time. If my unit tests are running,
I can't see them! I guess in a normal test run (via eclipse), eclipse must
connect to the running test workbench (perhaps via the specified port?)
and tell the test workbench what to run? Alternatively, perhaps my tests
are running silently & the results are in some file somewhere?
Can anyone help with this?
Many thanks
Andy
Ed Merks wrote:
> Andrew,
> D:sandbox3.3M6eclipsejrebinjavaw.exe -classpath
D:sandbox3.3M6eclipsepluginsorg.eclipse.equinox.launcher_1.0 .0.v20070319.jar
> -testLoaderClass
> D:sandbox3.3M6eclipseeclipseplugins/../junit-workspace
> -configuration
> -dev
>> Hi All,
>> tests on that.
>> invocations
>> Many Thanks
>> Andy
FUDForum. Page generated in 0.08032 seconds
