Home » Modeling » GMF (Graphical Modeling Framework) » Reference to ExpressionInOCL
Reference to ExpressionInOCL [message #205407] Fri, 12 September 2008 07:44 Go to next message
I need to create a reference to an ExpressionInOCL -> OpaqueExpression,
ExpressionInOCL<Classifier, Parameter> in my domain ecore model.
To do this I load the
platform:/plugin/org.eclipse.ocl.uml/model/OCLUML.ecore resource.
But when I try to reload the genmodel, first I'm getting errors:
"The package 'platform:/plugin/org.eclipse.ocl/model/OCL.ecore#//types' is
needed but not accessible from the Generator model."
same for //utilities and //expressions.
And then if I igonre these errors and try to Generate All, I'm getting
many package import problems in the generated projects.
What could be wrong?
Re: Reference to ExpressionInOCL [message #205441 is a reply to message #205407] Fri, 12 September 2008 09:16 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, W.F.,
This seems like a question more appropriate to the OCL newsgroup, which
I've included in my reply.
The UML binding for OCL (OCLUML.ecore) requires the abstract OCL
metamodel (OCL.ecore), so you need to reference its genmodel, also.
It may be worth noting that you will get more out of the UML binding for
OCL if you develop your metamodel with MDT UML2 instead of Ecore. For
example, UML semantics such as associations.
An important caveat: the serialization of OCL expressions (the AST) is
incomplete as defined by the OCL specification, particularly in the area
of references to dynamically-generated types such as collections and to
additional feature definitions. Simply including an ExpressionInOcl in
your metamodel will not be sufficient to persist OCL expressions. You
will also have to find containers for other objects that the MDT OCL
implementation's Environment persists in a special resource. Possibly
an annotation on the ExpressionInOcl would be appropriate.
HTH,
Christian
> is needed but not accessible from the Generator model."
Re: Reference to ExpressionInOCL [message #205448 is a reply to message #205441] Fri, 12 September 2008 10:00 Go to previous messageGo to next message
Yes, this adds itself as platform:/plugin/org.eclipse.ocl/model/OCL.ecore
along with the OCLUML.ecore.
I only have a few of such references. For example references to Operation
work OK, now I tried something from MDT OCL (ExpressionInOCL) and this
doesn't.
I thought I didn't have to worry about serialization because I'm only
using a reference to an element (ExpressionInOCL) that is already
persistent in another model.
I tried to manually fix the imports and dependencies in the projects
generated by GMF. But some packages are still missing, for example:
org.eclipse.ocl.edit
org.eclipse.ocl.expressions.provider
org.eclipse.ocl.types.provider
Are these part of the MDT OCL plugin?
> Hi, W.F.,
> HTH,
> Christian
Re: Reference to ExpressionInOCL [message #205453 is a reply to message #205448] Fri, 12 September 2008 10:15 Go to previous messageGo to next message
Hi, W.F.,
See some replies in-line, below.
HTH,
Christian
> platform:/plugin/org.eclipse.ocl/model/OCL.ecore along with the
> OCLUML.ecore.
>> for OCL if you develop your metamodel with MDT UML2 instead of Ecore.
>> For example, UML semantics such as associations.
> Operation work OK, now I tried something from MDT OCL (ExpressionInOCL)
> and this doesn't.
Well, that depends on whether your reference is a containment or not.
If not, then presumably persistence of the OCL is somebody else's
problem, as you say. :-)
Odd that GMF should require these plug-ins. In general, the reflective
item providers supplied by EMF automatically should be sufficient for
GMF's needs.
OCL currently does not deploy these because we would not customize them
beyond what the reflective provider does, anyway, and the code bloat
wasn't justified by the OCL porser's primary use case, which is parsing,
not EMF/GMF-generated editing of the AST.
However, I am intending in this release to provide an extra download for
those that want it that includes these plug-ins for all three OCL layers
(generic AST, Ecore, and UML). Until then, you can find Ed Willink's
generation of these plug-ins in the M2M QVTr component's CVS.
>> Hi, W.F.,
>> which I've included in my reply.
>> is incomplete as defined by the OCL specification, particularly in the
>> area of references to dynamically-generated types such as collections
>> and to additional feature definitions. Simply including an
>> ExpressionInOcl in your metamodel will not be sufficient to persist
>> OCL expressions. You will also have to find containers for other
>> objects that the MDT OCL implementation's Environment persists in a
>> special resource. Possibly an annotation on the ExpressionInOcl would
>> be appropriate.
>> HTH,
>> Christian
Re: Reference to ExpressionInOCL [message #205461 is a reply to message #205453] Fri, 12 September 2008 10:46 Go to previous message
OK, because I'm trying to do something rather simple here, I guess I can
reference a parent node of the ExpressionInOCL and then look for it by
hand. The parent will be from MDT UML (Value Pin or Value Specification
Action).
Thanks for your help.
Previous Topic:[Announce] GMF 2.1.2 M200809112022 is available
Next Topic:custom property tab problem
Current Time: Tue Jul 22 22:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.04911 seconds
