Home » Eclipse Projects » Eclipse Platform » Runtime NoClassDefFound 3.07
Runtime NoClassDefFound 3.07 [message #205233] Wed, 03 March 2004 09:35 Go to next message
Hi All,
I have two external jars, one for castor and one for castor
generated files. I have added these to my project properties
and my plugin compiles fine (although sometimes when I save my
plugin.xml I have to re-add the jars). My problem is that when
I run my plugin in the runtime env I get a NoClassDefFound exception.
I'm sure the solution is something that a more experienced Eclipse
developer could easily solve. Here is my .classpath:
<classpath>
<classpathentry kind="src" path="src"/>
<classpathentry kind="con" path="org.eclipse.pde.core.requiredPlugins"/>
path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry exported="true" kind="lib"
path="E:/UNetworks/KAFEProject/lib/kdas/kdas.jar"/>
path="E:/UNetworks/KAFEProject/lib/castor/castor-0.9.5.2-xml.jar "/>
<classpathentry kind="output" path="bin"/>
</classpath>
and my build.properties:
bin.includes = plugin.xml,\
META-INF/,\
kdasUI.jar,\
icons/,\
build.properties,\
bin/,\
kdas.jar,\
source.kdasUI.jar = src/
output.kdasUI.jar = bin/
source.kdas.jar =
source.castor-0.9.5.2-xml.jar =
src.includes = plugin.xml,\
icons/,\
build.properties,\
bin/
jars.compile.order = castor-0.9.5.2-xml.jar,\
kdas.jar,\
kdasUI.jar
any suggestions?
Andrew
Re: Runtime NoClassDefFound 3.07 [message #205298 is a reply to message #205233] Wed, 03 March 2004 10:50 Go to previous messageGo to next message
Originally posted by: ifedorenko.rogers.com
Do you have these jar files in runtime section of plugin.xml? Something
similar to
<runtime>
<library name="lib/log4j.jar">
<export name="*"/>
</library>
</runtime>
Note that you cannot use absolute paths and jarfiles have to be contains
within your plugin directory structure.
Andrew Boyd wrote:
> Hi All,
> <classpath>
> </classpath>
> META-INF/,\
> kdasUI.jar,\
> icons/,\
> build.properties,\
> bin/,\
> kdas.jar,\
> source.kdas.jar =
> icons/,\
> build.properties,\
> bin/
> kdas.jar,\
> kdasUI.jar
> any suggestions?
> Andrew
Re: Runtime NoClassDefFound 3.07 [message #205342 is a reply to message #205298] Wed, 03 March 2004 11:47 Go to previous messageGo to next message
Hi Igor,
Thanks for your response. I don't have the jars mentioned in my
plugin.xml. Should I do this by hand or is there a better way?
Do I need to create the lib dir myself or will eclipse do it for
me somehow?
Thanks again,
Andrew
> similar to
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> Andrew Boyd wrote:
> > Hi All,
> > <?xml version="1.0" encoding="UTF-8"?>
> > <classpath>
> > </classpath>
> > META-INF/,
> > kdasUI.jar,
> > icons/,
> > build.properties,
> > bin/,
> > kdas.jar,
> > source.kdas.jar =
> > icons/,
> > build.properties,
> > bin/
> > kdas.jar,
> > kdasUI.jar
> > any suggestions?
> > Thanks,
> > Andrew
Re: Runtime NoClassDefFound 3.07 [message #205414 is a reply to message #205342] Wed, 03 March 2004 12:34 Go to previous message
I added the lib dir and the jars to the lib dir by hand and
added the reference to the jars just like you said and it Works!
Although everytime I save my plugin.xml I have to re-add my external
jars to my plugin env. But at least I can run now.
Thanks Igor!
Andrew
Andrew Boyd wrote:
> Hi Igor,
> me somehow?
> Thanks again,
> Andrew
> > similar to
> > <runtime>
> > <export name="*"/>
> > </library>
> > </runtime>
> > Andrew Boyd wrote:
> > > Hi All,
> > > <classpath>
> > > </classpath>
> > > META-INF/,
> > > kdasUI.jar,
> > > icons/,
> > > build.properties,
> > > bin/,
> > > kdas.jar,
> > > source.kdas.jar =
> > > icons/,
> > > build.properties,
> > > bin/
> > > kdas.jar,
> > > kdasUI.jar
> > > any suggestions?
> > > Thanks,
> > > Andrew
Previous Topic:OpenGL plugin
Next Topic:How to set different CellEditor to different cells in one column
Current Time: Thu Jul 17 07:08:54 EDT 2025
Powered by FUDForum. Page generated in 0.04885 seconds
