Home » Language IDEs » ServerTools (WTP) » Tomcat/shared/lib and WTP
Tomcat/shared/lib and WTP [message #205183] Fri, 30 November 2007 13:43 Go to next message
Hi all,
Is there a way to load tomcat_home/shared/lib/*.jar files into Eclipse
when Tomcat is running via WTP ?
"Load into Eclipse" I means put in, both, Eclipse and Tomcat
classpaths. Like Tomcat Libraries ( automatically loaded when a new
Web Project is created ) .
I try a workaround, copying catalina.properties file found in
conf/catalina.properties to
metadata/.plugins/org.eclipse.wst.server.core/tmp?/conf/ in my
Eclipse workspace and then edit shared.loader., but without success.
Any idea ?
PS: Tomcat 5.0.x and Eclipse 3.3.1
Re: Tomcat/shared/lib and WTP [message #205191 is a reply to message #205183] Fri, 30 November 2007 13:48 Go to previous messageGo to next message
See if
http://wiki.eclipse.org/WTP_Tomcat_FAQ#Why_are_classes_in_my _Tomcat_installation.27s_shared.2Flib_not_seen_by_my_Web_app lication.3F
helps. It was written for WTP 1.5.x, but applies to WTP 2.0.x except
that catalina.properties is already imported. You can modify the
shared.loader property to replace "${catalina.base}" with
"${catalina.home}" or append strings that use "${catalina.home}".
Larry
Mauro wrote:
> Hi all,
> Any idea ?
> Thanks
Re: Tomcat/shared/lib and WTP [message #205198 is a reply to message #205191] Fri, 30 November 2007 14:17 Go to previous messageGo to next message
This is a workaround for runtime, right ? I also need to import *.jar into
classpath, to use autocompletion in editor and so on. Is there a way to do
it automatically ? Like WTP does with tomcat/common/lib (servlet-api, ant,
jsp-api, etc)
Re: Tomcat/shared/lib and WTP [message #205206 is a reply to message #205198] Fri, 30 November 2007 14:40 Go to previous messageGo to next message
> into classpath, to use autocompletion in editor and so on. Is there a
> way to do it automatically ? Like WTP does with tomcat/common/lib
> (servlet-api, ant, jsp-api, etc)
This would be one case where you would use the the Build Path page of
the projects properties to add these jars, rather than J2EE Module
Dependencies. Doing something automatically that was also robust would
be very difficult to implement.
I would recommend creating a User Library containing the shared jars and
add that to the project's build path.
Larry
Re: Tomcat/shared/lib and WTP [message #205222 is a reply to message #205206] Fri, 30 November 2007 14:51 Go to previous message
The worst part of this approach is that every new jar I need to reload the
User Library, adding the new element.
Previous Topic:JSP Editor
Next Topic:Eclipse & Axis2 Problem
Current Time: Tue Nov 18 17:35:22 EST 2025
Powered by FUDForum. Page generated in 0.05286 seconds
