Home » Language IDEs » AspectJ » Create aspects with .aj extension
Create aspects with .aj extension [message #19718] Tue, 29 April 2003 13:47 Go to next message
Originally posted by: rsteele.etracksolutions.com
I just started looking into AspectJ and AJDT, so pardon me if this is a
silly question, but how can I create an aspect in Eclipse that has an *.aj
extension instead of a *.java extension?
Rich
Re: Create aspects with .aj extension [message #20004 is a reply to message #19718] Thu, 08 May 2003 11:29 Go to previous messageGo to next message
Originally posted by: adrian_colyer.uk.ibm.com
On Tue, 29 Apr 2003 17:47:29 +0000 (UTC), Richard A. Steele
> *.aj
This is a feature we hope to support via preference setting that will
control what file extension the AspectJ Wizard uses when it creates
aspects. Unfortunately that ability has proven surprisingly difficult to
implement and we had to drop the feature temporarily from the last release.
The only way to get a ".aj" extension right now is to create the aspect as
normal (".java" extension) and then go into the resources view, where
refactor->rename gives you the opportunity to change the file extension
(whereas the same action from the package explorer does not).
-- Adrian
Re: Create aspects with .aj extension [message #21064 is a reply to message #20004] Mon, 12 May 2003 13:11 Go to previous message
> aspects.
I saw this is already an open issue after I made the post.
> implement
Isn't it funny the world sometimes works that way? :-)
Bummer.
Yep, I did discover that. It's a pain, but it does seem to work.
There's another way I might solve this: put all of our aspects into a
package with "aspect" in it. Another might be to just allow AspectJ code
and Java code intermingle; however, keeping the two separate for as long
as possible was one of our "risk mitigation" strategies...
Thanks again!
Rich
Re: Create aspects with .aj extension [message #566201 is a reply to message #19718] Thu, 08 May 2003 11:29 Go to previous message
> *.aj
-- Adrian
Re: Create aspects with .aj extension [message #566484 is a reply to message #20004] Mon, 12 May 2003 13:11 Go to previous message
> aspects.
> implement
Bummer.
Thanks again!
Rich
Previous Topic:Aspect Libraries
Next Topic:Add-in possible?
Current Time: Thu Nov 06 14:50:44 EST 2025
Powered by FUDForum. Page generated in 0.03370 seconds
