Home » Eclipse Projects » DSDP - Target Management » EclipsCon 2007 Tutorial on RSE
EclipsCon 2007 Tutorial on RSE [message #19698] Fri, 28 March 2008 15:41 Go to next message
I am new to Eclipse and am working on integrating Eclipse and RSE into our
development environment. I was trying to follow the EclipseCon 2007
Tutorial slides but when I imported the source into Eclipse, there appear
to be many unresolved references. Here are a few that could not be
resolved: org.eclipse.rse.core.SystemBasePlugin, org.eclipse.rse.model,
org.eclipse.rse.ui.SystemResources, and
org.eclipse.rse.shells.ui.ShellResources. Is the tutorial source code
outdated or do I have to download something else to get references
resolved? Thanks.
Re: EclipsCon 2007 Tutorial on RSE [message #19897 is a reply to message #19698] Mon, 31 March 2008 10:28 Go to previous message
Hello Denise,
the 2007 tutorial sources are outdated, please use the 2008 tutorial
ones. I just added the links to the TM homepage:
http://www.eclipse.org/dsdp/tm/
These will work against TM 3.0M5 and (with small modifications)
against TM 2.0.x
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
Re: EclipsCon 2007 Tutorial on RSE [message #573194 is a reply to message #19698] Mon, 31 March 2008 10:28 Go to previous message
Hello Denise,
against TM 2.0.x
Previous Topic:how to filter out the appearance of context menu over RSE's remote system view
Next Topic:how to filter out the appearance of context menu over RSE's remote system view
Current Time: Sat Nov 08 08:04:50 EST 2025
Powered by FUDForum. Page generated in 0.03804 seconds
