Deploy in TOMCAT tutorial [message #19695] |
Fri, 20 April 2007 11:48  |
Originally posted by: rhernandez_64.hotmail.com
I use rap.psf and add org.eclipse.rap.demo.feature, every thing is OK the
import download the plugins but in the root of org.eclipse.rap.feature
doesnt appear the deploy tutorial
regards
Re: Deploy in TOMCAT tutorial [message #19914 is a reply to message #19786] |
Mon, 23 April 2007 05:10   |
Originally posted by: fappel.innoopract.com
I just checked the CVS - the current version number of the
deployment_tutorial.html is 1.1, so it is in the repository. It is true that
the 'org.eclipse.rap.demo.feature' isn't added to the rap.psf file, so it
has to be checked out manually. Maybe this will be changed in the future and
the tutorial will be added to the next milestone help plugin. After that we
will provide it online as an infocenter installation.
Ensure that you have checked out the 'org.eclipse.rap.demo.feature' and not
the 'org.eclipse.rap.feature' which is used for the milestone build. We also
tried the anonymous account but the deployment_tutorial.html was there.
Maybe try the CVS Repository Exploring perspective to find it. If you are
still not able to check out the complete project, please give us some more
hints for troubleshooting, since maybe not only the tutorial is missing - so
putting the tutorial into the wiki would not be the solution.
Ciao
Frank
"Rafael Hernandez" <rhernandez_64@hotmail.com> schrieb im Newsbeitrag
news:c48a6bd65be8db3095c5528f6bd1df38$1@www.eclipse.org...
> You are right, is org.eclipse.rap.demo.feature but is not there
> deploy_tutorial.html
> this is part of my rap.psf
> <project
> reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,org.eclipse.rap/org.eclipse.rap.demo,or g.eclipse.rap.demo.feature "
Re: Deploy in TOMCAT tutorial [message #20322 is a reply to message #20266] |
Thu, 26 April 2007 05:14  |
did you checkout the servlet bridge bundles and modified the
webappBuilder.xml as described in the tutorial?
Ciao
Frank
news:fcc754d44c34162ba597f641b07ddbc4$1@www.eclipse.org...
> When Run ant build of webappbuilder.xml the console display
> BUILD FAILED
> C:\workspace\org.eclipse.rap.demo.feature\script\webappBuild er.xml:64: The
> following error occurred while executing this line:
> C:\workspace\org.eclipse.rap.demo.feature\script\webappBuild er.xml:81:
> C:\eclipse\rap\org.eclipse.equinox.servletbridge\bin not found.
> Hot fix it ?
> Rafael Hernandez
> Caracas - Venezuela
FUDForum. Page generated in 0.06392 seconds
