Home » Newcomers » Newcomers » My Plugins don't work without running first eclipse with -clean option.
My Plugins don't work without running first eclipse with -clean option. [message #204466] Thu, 12 April 2007 05:35 Go to next message
Originally posted by: yura.zharkovsky.telelogic.com
Hi everybody,
I have an issue when I intall my plugins to eclipse.
The issues is:
This is very annoying since users who want to use my plugins have to
perform this clean.
Does Eclipse support cleaning configuration in batch mode ?.
For example the solution may be follow:
Let say when my plugins are intalled I will run eclipse in batch with
clean option without opening eclipse itself. (I don't knoe how to do it:( )
Yura.
Re: My Plugins don't work without running first eclipse with -clean option. [message #204489 is a reply to message #204466] Thu, 12 April 2007 08:36 Go to previous message
Yura,
I'm sure there would be a headless application you could invoke to
accomplish this. Probably even trying to invoke a non-existing
application while passing the -clean flag would do the trick. But I
think another way to accomplish it would be to delete all the
files/folders in the configuration directory except the config.ini.
Yura wrote:
> Hi everybody,
> The issues is:
> perform this clean.
> it:( )
> Yura.
Previous Topic:Code Completion doesn't work
Next Topic:View Report As PDF Not Working
Current Time: Mon Nov 17 18:30:44 EST 2025
Powered by FUDForum. Page generated in 0.08491 seconds
