Home » Archived » Test and Performance Tools Platform (TPTP) » Performance Monitor Agent crash on WinXP
Performance Monitor Agent crash on WinXP [message #19635] Wed, 08 June 2005 11:39 Go to next message
Originally posted by: stefano.scheda.formula.it
I'm trying to test TPTP, by following the EclipseCon 2005 Tutorial, on a
WinXPSP2 machine with Eclipse 3.0.2 and JRE 1.4.2.
When I try to start a new profile (page 46 of the tutorial) Eclipse takes
some time "launching..." (rebuilding the workspace projects?) then when it
moves to launch the agent I get a Windows GPF ("Performance Monitor Agent
has encountered a problem...").
The system event log contains this application error:
Faulting application perfmonagent.exe, version 3.1.0.0, faulting module
rac.dll, version 3.1.0.0, fault address 0x00001d79.
and the agent controller service.log, modified to loggingLevel="DEBUG",
lists these as the last entries (simplified):
msg="Forwarding command to agent: tag=25 agent=PerfmonAgent - #1118244647735
pid=4592" severity="5"
msg="Sent 112 bytes to agent 5e1422e8-2eb9-4b16-9849-72d6d2ac0279"
severity="5"
msg="Validated message of 104 bytes" severity="5"
msg="Processing message of length 104 bytes." severity="5"
msg="Processing command: tag=25" severity="5"
msg="Sent 104 bytes to agent 5e1422e8-2eb9-4b16-9849-72d6d2ac0279"
severity="5"
any help appreciated
TIA
Stefano Scheda
Re: Performance Monitor Agent crash on WinXP [message #19725 is a reply to message #19635] Thu, 09 June 2005 13:58 Go to previous messageGo to next message
Originally posted by: lars.nospam.nix_ohlenDOT.se
I never got the Performance Monitor to work until I upgraded to 3.2A of
TPTP.
You should also note that there is a bug that can prevent the Performornace
Monitor chart generator from rendering values.
If this happens you should try to change your national settings and change
the decimal separator character to a period (e.g a dot).
/L
"Stefano Scheda" <stefano.scheda@formula.it> skrev i meddelandet
news:d873fs$c81$1@news.eclipse.org...
> #1118244647735 pid=4592" severity="5"
> severity="5"
> severity="5"
> TIA
> Stefano Scheda
Re: Performance Monitor Agent crash on WinXP [message #19974 is a reply to message #19725] Tue, 14 June 2005 04:54 Go to previous messageGo to next message
Hi Stefano,
There was a known issue in the agent building up to 3.2A. The locale bug
is a known issue and has been fixed in Hyades 3.3, but not in 3.2A.
Unless there is a particular reason why you require Hyades TPTP 3.1 then
I think your problems might be fixed just by upgrading to a more recent
Hyades version.
Let me know how you get on, or if this is not an option.
George
Lars Ohlén wrote:
> TPTP.
> /L
>>severity="5"
>>severity="5"
>>TIA
>>Stefano Scheda
Re: Performance Monitor Agent crash on WinXP [message #20006 is a reply to message #19974] Tue, 14 June 2005 08:06 Go to previous message
Hi George,
actually I've no real need to use the Performance Monitor Agent. I was just
following the EclipseCon 2005 tutorial as a way to get started with TPTP,
and my real interest is profiling J2EE apps running under JBoss.
In fact I'm much more worried about a conflict between the TPTP (and its
requisites EMF and XSD) installation and the other plugins I had installed
in my Eclipse env, as described in another post just few hours ago.
Stefano
"George Christelis" <george.christelis@scapatech.com> wrote in message
news:d8m612$vra$1@news.eclipse.org...
> Hi Stefano,
> is a known issue and has been fixed in Hyades 3.3, but not in 3.2A. Unless
> there is a particular reason why you require Hyades TPTP 3.1 then I think
> your problems might be fixed just by upgrading to a more recent Hyades
> version.
> George
Previous Topic:Installation conflict
Next Topic:TPTP and CDT links
Current Time: Tue Nov 11 22:03:23 EST 2025
Powered by FUDForum. Page generated in 0.22183 seconds
