| linux/GTK RC1/RC2 fails to start [message #19621] |
Sun, 01 October 2006 07:23  |
Originally posted by: axel.mueller.amit-services.de
eclipse is running on my amd64/opensuse10.1 with 32bit java 1.4.xx without
any problem. but:
Trying to start the eclipse installed with epf-composer, I get a dialogbox
saying:
Eclipse Process Framework Composer cannot be started while another instance
is running. Switch to the running instance or close it and restart the
application again.
Of course, no other instance is running and MOZILLA_FIVE_HOME is set.
Thanks and best regards,
Axel Mueller
| Re: linux/GTK RC1/RC2 fails to start [message #566163 is a reply to message #19621] |
Sun, 01 October 2006 12:37  |
Originally posted by: christopher.fuhrman.etsmtl.ca
Axel Müller wrote:
> any problem. but:
> saying:
> application again.
I don't use linux much these days, and I have no idea of how the epf
composer runs, but perhaps it's simply a ".lock" (or similar flag) file
that is present from when composer might have crashed before.
Maybe you can look for such files and try to clean them. It's just a
wild guess - hope nobody minds.
Prof. Christopher Fuhrman
Department of Software and IT Engineering
University of Quebec - École de technologie supérieure (ETS)
http://profs.logti.etsmtl.ca/cfuhrman/index.shtml?en
+1 (514) 396 8638
| Re: linux/GTK RC1/RC2 fails to start [message #566236 is a reply to message #19666] |
Sun, 01 October 2006 14:57  |
No, there's nothing like a lock file. I fear it's a OpenSuse/x86_64 or a
OpenSuse/GTK problem. I hope, that the upcoming 1.0 release of EPF comes as
a plugin and installs on my running eclipse (eclipse-SDK-3.2-linux-gtk).
thanks,
Axel Müller
> Axel Müller wrote:
>> without any problem. but:
>> dialogbox saying:
>> instance is running. Switch to the running instance or close it and
>> restart the application again.
axel.mueller@amit-services.de
http://www.amit-services.de
tel +49 +6322 680 668
mobil +49 0160 973 483 27
FUDForum. Page generated in 0.04040 seconds
