Home » Eclipse Projects » Eclipse Platform » Eclipse 2.1.1 Vanishing Trick
Eclipse 2.1.1 Vanishing Trick [message #204295] Mon, 01 March 2004 16:23 Go to next message
Originally posted by: barkingcat.bellsouth.net
Any one have any idea why Eclipse 2.1.1 would after a few hours working
with it would suddenly disappear ie; close, with no warning. It started
I think when I installed JSDK 1.4.1. I have since installed
JSDK1.4.2_01, and issue still exists. There seems to be no pattern to
this behaviour - I can be edited Java classes, JSP's, whatever.
Suddenly, it disappears.
Thanks in anticipation...
Re: Eclipse 2.1.1 Vanishing Trick [message #204311 is a reply to message #204295] Mon, 01 March 2004 17:38 Go to previous messageGo to next message
it is magic
Re: Eclipse 2.1.1 Vanishing Trick [message #204391 is a reply to message #204311] Mon, 01 March 2004 19:25 Go to previous messageGo to next message
> it is magic
Thanks, that's just what i thought! :>)
Re: Eclipse 2.1.1 Vanishing Trick [message #204498 is a reply to message #204295] Tue, 02 March 2004 03:23 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
Do you have any Exceptions in your workspace/.metadata/.log file?
Have you set vm parameters for Eclipse (if not, you should use at
least -vmargs -Xmx192M option: eclipse -vmargs -Xmx192M)?
Also, you should use Eclipse 2.1.2 (which is a bug-fix release over 2.1.1).
HTH,
Csaba
"Phil" <barkingcat@bellsouth.net> wrote in message
news:c209d5$28b$1@eclipse.org...
Re: Eclipse 2.1.1 Vanishing Trick [message #204555 is a reply to message #204498] Tue, 02 March 2004 09:22 Go to previous messageGo to next message
Horváth, Csaba wrote:
> HTH,
> Csaba
Yes, there are exceptions in log file - here is a sample:
!SESSION Mar 01, 2004 17:05:03.812
java.version=1.4.2_03
Command-line arguments: -os win32 -ws win32 -arch x86 -data c:\workspace
-install file:C:/eclipse/
!ENTRY org.eclipse.ui 4 4 Mar 01, 2004 17:05:03.828
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Mar 01, 2004 17:05:03.843
!MESSAGE Failed to execute runnable (java.lang.Exception: PANIC)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2332)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:101)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1815)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1549)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.ui 4 4 Mar 01, 2004 17:05:03.843
!MESSAGE
*** Stack trace of contained exception ***
!MESSAGE PANIC
!STACK 0
at net.sf.colorer.impl.BaseEditorNative.getLineRegions(Native Method)
net.sf.colorer.impl.BaseEditorNative.getLineRegions(BaseEdit orNative.java:143)
at net.sf.colorer.swt.TextColorer$3.run(TextColorer.java:109)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
!SESSION Mar 01, 2004 18:13:57.390
!ENTRY org.eclipse.ui 4 4 Mar 01, 2004 18:13:57.390
!MESSAGE Invalid preference page path: AntView
Re: Eclipse 2.1.1 Vanishing Trick [message #204603 is a reply to message #204555] Tue, 02 March 2004 10:30 Go to previous messageGo to next message
From these exceptions it seems that you have installed the colorer plugin,
and it is which cause the root problem. Try to remove this plugin to see
whether this plugin causes the problem really. Or, if you use a version
different from 0.5.0 you should download that version of the plugin.
HTH,
Csaba
news:c22558$321$1@eclipse.org...
> Horv
Re: Eclipse 2.1.1 Vanishing Trick [message #204877 is a reply to message #204603] Tue, 02 March 2004 20:04 Go to previous message
> HTH,
> Csaba
>>>Hi,
> 2.1.1).
>>>HTH,
>>>Regards,
>>>Csaba
>>BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
>>!STACK 0
>>at
>>at
> a:858)
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at
>>at
> .java:25)
>>!MESSAGE
>>!MESSAGE PANIC
>>!STACK 0
>>at
> 3)
>>at
>>at
> a:858)
>>at
>>at
> .java:25)
THanks - will try that and let you know if that resolved the issue.
Have to say, I installed Eclipse 3.0 M7 on another box, with no plugins,
and am not seeing the problem.
Previous Topic:Eclipse 2.1.2 on SuSE Linux 9.0: No JRE anymore after installing eclipse examples
Next Topic:Actions and MenubarPath
Current Time: Fri Nov 21 08:16:46 EST 2025
Powered by FUDForum. Page generated in 0.03859 seconds
