Home » Archived » BIRT » Tutorial - need help please.
Tutorial - need help please. [message #19613] Thu, 17 March 2005 00:02 Go to next message
Originally posted by: edlinoor.xgo.com.my
I just downloaded birt-designer-1.0M1.zip for the tutorial. I have
followed all instructions and eventually managed to installed it. However
when I get into the tutorial I encountered this problems in Eclipse:
1) The list/table "table1" must be able to access one data set
2) The value of the property "keyExpr" is required
Did I missing something? It occured after I created a new report by
clicking on File -> New -> Report in Eclipse.
Thanks.
Ed.
Re: Tutorial - need help please. [message #20596 is a reply to message #19613] Fri, 18 March 2005 12:36 Go to previous messageGo to next message
Ed,
I tried out the tutorial steps using the S20050314 stable build, and it
worked for me. Did the error appear in the Problems view? By default, this
view shows problems for all reports (indeed, all files, including Java
files) in all open projects. Perhaps there is another report in your project
that is missing some information.
The error messages suggest that you have a table with one grouping level,
but that the table is not yet bound to a data set, and the group key is not
yet set. However, these tasks should be done as you follow the tutorial
steps to add columns to the report, and as you edit the groups. That's why I
wonder if the errors are coming from a different report file.
If, after this, you still have problems, please send me your design file and
I'll figure out what's wrong. Perhaps there is something amis with this
design file, or perhaps there is a bug in the software.
- Paul
Paul Rogers
BIRT PMC
"Ed Ramlan" <edlinoor@xgo.com.my> wrote in message
news:d1b30r$rjf$1@www.eclipse.org...
> Thanks.
> Ed.
Re: Tutorial - need help please. [message #21609 is a reply to message #20596] Mon, 21 March 2005 00:56 Go to previous message
HI,
Thanks for the reply... I tried to re-install everything and it seems to
work now... I'm using the stable build... thanks...
Previous Topic:3.1 support
Next Topic:Draft Deployment Info
Current Time: Sun Jul 13 05:16:05 EDT 2025
Powered by FUDForum. Page generated in 0.05403 seconds
