Home » Archived » BIRT » Library Refresh - changes not recognized
Library Refresh - changes not recognized [message #204096] Thu, 30 November 2006 10:56 Go to next message
Originally posted by: eclipse.junga.com
I am using Birt Designer 2.1.1.v200609xx-xxxx.
I have a library with some data sources, themes/styles, and a chart. When I
change the chart in the library, I can not get the change to be recognized
report design that includes it.
* I tried right clicking on the library and choosing "refresh" in every
place that the lirary is visible.
* I tried deleting the chart and re-adding it.
* I tried restarting eclispe / closing all files, etc...
* I tried renming the chart in the lib
* I tried deleting and createing a new chart in the lib with a new name, but
still, only the original chart shows up in the lib exployer.
The only thing that I have found that works is removing the library from the
report and re-adding it. But now that my report relies on a datasource from
the lib, it won't let me do that unless I remove that dependancy first.
Is this a bug? Or am I missing something? Is there a work around? should I
am tempted to try the newest un-released version? (We use 2.0 for
production - I am trying libraries in a sandbox). Are library's better
supported in 2.2?
Also, where are the library elements cached? Can I manually clear it?
--BobG
Re: Library Refresh - changes not recognized [message #204138 is a reply to message #204096] Thu, 30 November 2006 11:37 Go to previous messageGo to next message
Update: I found out how to get the changes recognized. I choose "Add
Library" from the context menu of the library and chose to overwrite the
existing library. Then I was prompted that the library my report uses might
have changed an to re-open the report ot see the changes.
I would still like to know if the "refresh" command on the library's context
menu should have done this or does that have a different purpose. Is
re-adding the library a work around to the "refresh" not working? Or, is
this by design?
--BobG
"Bobg" <eclipse@junga.com> wrote in message
news:ekmv01$la8$1@utils.eclipse.org...
> I change the chart in the library, I can not get the change to be
> recognized report design that includes it.
> but still, only the original chart shows up in the lib exployer.
> the report and re-adding it. But now that my report relies on a datasource
> from the lib, it won't let me do that unless I remove that dependancy
> first.
> supported in 2.2?
> --BobG
Re: Library Refresh - changes not recognized [message #205964 is a reply to message #204138] Tue, 12 December 2006 10:39 Go to previous message
I face the same issue now. See and vote for this bug here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=167662
Leos
Bobg napsal(a):
> this by design?
> --BobG
>> first.
>> supported in 2.2?
>> --BobG
Previous Topic:Dynamic Page Break
Next Topic:"BIRT Report Viewer" text in report
Current Time: Tue Jul 29 02:45:01 EDT 2025
Powered by FUDForum. Page generated in 0.26807 seconds
